Old 08-29-2012, 07:21 PM   #1
Blueclyde
Drives: 2023 ZLE
Turning Off Traction Control and PTM
I'm sure this has been posted before. I tried a search and it brought back pages of threads...
I would like to know how to completely disable all traction control and PTM. When I press the T/C button one time I get the T/C off symbol on the dash. Is this all that is required?
I know it is there to keep the car inline, which I can appreciate. Every once in a while I would like to be able to get into it without hearing the traction control. It sounds like I'm bouncing off the rev limiter at 4500 rpm. I'm pretty sure it is the T/C and would like to turn it off.
I know, be careful...
Blueclyde is offline   Reply With Quote
Old 08-29-2012, 07:24 PM   #2
HDRDTD
I haven't tried it with the ZL1 yet, but with the SS, you held the T/C button in for about 7-10 seconds and it turned everything off.
Old 08-29-2012, 07:24 PM   #3
Pflyn lo
Pflyn lo's Avatar
Drives: 2013 summit white zl1
Press it twice, it will the say competition mode. The tc light will be lit also indicating it s turned off.
Pflyn lo is offline   Reply With Quote
Old 08-29-2012, 07:24 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
hold down the traction control button for 5 secs...traction control and active handling will turn off and both icons illuminate
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 08-29-2012, 07:40 PM   #5
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
That's for the SS not a ZL1.
RoketRdr is offline   Reply With Quote
Old 08-29-2012, 07:45 PM   #6
Blueclyde
Drives: 2023 ZLE
I tried this and the T/C and A/H lights did not come on. I guess I will try it again.
Old 08-29-2012, 07:46 PM   #7
Blueclyde
Drives: 2023 ZLE
I think the ZL1 coupe system is different. I wonder if your Vert will be this way (similar to the SS).
Old 08-29-2012, 08:01 PM   #8
RoketRdr
RoketRdr's Avatar
HDRDTD is correct. Hold it down for 7-10 seconds and everything is turned off. Press it twice and you enter PTM mode selection. Press it once and the traction control is by-passed but Stabilitrak is still active.
Old 08-29-2012, 08:39 PM   #9
HDRDTD
According to page 1-17 in the owners manual, it's as I thought.
To turn off both traction control and electronic stability control, press and hold the TCS/StabiliTrak button on the console in front of the shift lever.
Press the TCS/StabiliTrak button again to turn on both systems.
Old 08-29-2012, 08:55 PM   #10
Blueclyde
Drives: 2023 ZLE
I will try this next time I drive it.
Old 08-29-2012, 09:37 PM   #11
JMAN311
JMAN311's Avatar
Drives: 2013 F-150 Limited
This is all you have to do. Hold the button that is circled below for 5 sec. When you first press it the traction control light will come on, after the full 5 sec the stabilitrac light will come on.
Name:  traction control.jpg
There just might be a 2016 Camaro or Corvette in my future...
Previous Chevy's
2013 Camaro ZL1 A6|SIM
2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int
2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed
2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned
JMAN311 is offline   Reply With Quote
Old 08-29-2012, 09:50 PM   #12
Zee-Ell-One
YOOZ GOTA B FREKN KIDN ME
Zee-Ell-One's Avatar
Drives: 2013 6mt ZL1#826
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT
2013 ZL1 Camaro 6MT
2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab
2012 Aprilia RSV4 R
2015 Husqvarna FC450 Motomadness
First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter
Zee-Ell-One is offline   Reply With Quote
Old 08-29-2012, 11:24 PM   #13
KKreme15
KKreme15's Avatar
Drives: C6 Z06
To take off T/C just press the button once and you're good
KKreme15 is offline   Reply With Quote
Old 08-30-2012, 06:35 AM   #14
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Anyone know (not guess, know) the difference between running in Sport ('M') mode with traction and stability turned off, and PTM5?
Drew P is offline   Reply With Quote
