Old 08-31-2012, 04:57 PM   #1
homerlex
Wait'ns the hardest part
homerlex's Avatar
Drives: 2010 2LT/RS || 2001 Tahoe
Is P0449 cover by emissions warranty?
Anyone know for sure if the "Evaporative Emission Control System Vent Valve/Solenoid Circuit" is covered by the emissions warranty?
My engine light came on the day (perhaps the day after, I swear) I had my car for 3 years (12,000 miles). I was hoping it was the gas cap but the light never went off. I just got a code reader and the code is P0449.
I emailed the dealer but want to know if someone here knows the answer for sure.
2LT/RS Black/Black, Manual with Polished AL Wheels
Order #NKNB5D Vin: 2G1FG1EV7A9132544
1100 - 06/09/2009 | 2000 - 06/18/2009 | 2500 - 06/23/2009 | 3000 - 06/24/2009
3100 - 07/14/2009 | 3300 - 07/14/2009 | 3400 - 07/25/2009 | 3800 - 08/04/2009
4B00 - 08/05/2009 | 4100 - 08/06/2009 | 4200 - 08/08/2009 | 5000 - 08/20/2009 |6000 - 08/22/2009
Target Production Week:Originally: 7/27, pushed to 8/10 then back to 7/27
homerlex is offline   Reply With Quote
Old 08-31-2012, 05:13 PM   #2
Pt_killa
Pt_killa's Avatar
Drives: Black 2010 Camaro V6
Could be a couple of problems, but regardless of what it is, should be covered, don't know why not....
(Sold Sept 2015) Stock 18" Heritage w/ BFG G-Force ZR tires / Blacked out bowties and tail lights / DIY Remote-Mount Turbo Kit (Precision 6776S .81ar ex. @ 6.5psi, Tial 38mm WG, Greddy Type-S BOV) / RX Catch Can / RX-FTI 3600 Stall / Blue Well Lights / Team LLT
Pt_killa is offline   Reply With Quote
Old 09-01-2012, 06:03 AM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Powertrain - Auxiliary Emission Controls - ISO/SAE ControlledDescriptionEVAP Vent Solenoid Control Circuit Conditions
CauseEngine speed over 600 rpm, system voltage from 6-18v, then the PCM detected that the Actual and Commanded state of the Vent Control solenoid control circuit did not match for over 5 seconds
Emission system stuff is supposed to be good for 100,000mi.
But I've seen stuff like this and other "purge valves" not covered beyond 3 yrs.
Use your reader to clear it and perhaps disconnect the battery as well to reset the "control circuit", then see if it returns.
If it does, I'd take it to the dealer and play dumb. If he tries to charge, be ready with a littany of federal emission longevity requirements (they're outlined in your owner's manual) and hope for the best.
Old 09-05-2012, 11:59 AM   #4
homerlex
homerlex's Avatar
The service manager's response was
"the car is out off bumper to bumper but that is no problem we will take care of it for you its possible it needs a vent valve"
So, its unclear if its supposed to be covered under the emission warranty or not. In any case if its just the vent valve they are gonna cover it.
Car goes in on Friday. I'll let you know what happens.
Old 09-05-2012, 01:37 PM   #5
Ventmaster
Ventmaster's Avatar
Old 09-05-2012, 01:46 PM   #6
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
The only emission components covered beyond 3/36 is the PCM, ABS module, fuel control module, and catalytic converters. That's it. Cam actuators for the L99 have 7/70 warranty, for California-equipped emission systems.
Bye bye, Bumblebee!
Old 09-05-2012, 02:05 PM   #7
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
It aways seems like pulling teeth when dealing with a warrenty issue
Old 09-07-2012, 04:24 PM   #8
homerlex
homerlex's Avatar
The service manager called and said they need to replace the EVAP canister. He needs to order it and I'll need to leave the car the for a full day. Total cost to me will be $0
I still don't know for sure if its under emissions warranty or if it because the light went on the last day of my 3yrs. I'll try to find out after its all done.
Old 09-07-2012, 04:37 PM   #9
Ventmaster
Ventmaster's Avatar
Isn't that just a can of charcoal?
I think you can ruin one if you "top off the tank" when you fill up with gas.
the gas sloshes into the canister and saturates the charcoal- it's just designed to absorb vapors.
Old 09-11-2012, 09:20 AM   #10
homerlex
homerlex's Avatar
I don't know exactly what it is - I've never topped off the tank so that wasn't the problem
The car goes back for the repair at the end of this week.
Old 09-11-2012, 01:56 PM   #11
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
CAI intake/ADM Scoop/Stainless Power Headers/Dynatech cat back exhaust/Vitesse Throttle Control/ Ported Throttle Body/QTP Electric Cutouts/ 3.91 gears and janetty rear posi/ Tuned by Janetty racing
mydreamcar is offline   Reply With Quote
Old 09-15-2012, 01:11 PM   #12
homerlex
homerlex's Avatar
Car is fixed. I picked it up today. Looks like the part is not covered by the emissions warranty but the covered it anyway.
This is what is said on the invoice:
"OK TO GOODWILL JUST OUT OF WARRANTY"
Below is what it says under the work done. It was the vent solenoid valve that was bad but it came with a canister:
LOWERED REAR CRADLE TO ACCESS EVAP. EMISSION CANISTER. REMOVED AND REPLACED EVAP EMISSIONS CANISTER/VENT SOLENOID VALVE ASSEMBLY. REASSEMBLED CRADLE.
Old 11-09-2012, 08:38 PM   #13
Travo
Travo's Avatar
Drives: 2010 CGM 2LT/RS
Same thing just happened to mine, unfortunately mine is about 3.5 years old. Any clue how much it would have cost if the dealership didn't cover it? Also any chance they say what actually caused this problem too? Weird both our cars are 3 years old and same problem. Thanks for the help.
Travo is offline   Reply With Quote
Old 11-09-2012, 08:58 PM   #14
Rhyder
Drives: 2012 45 Anniversary Vert
It is, buddy of mine errored from day one, took it in three times. Funny thing, the third time they said it wasnt covered because he had a tune....an ongoing problem they had been trying to fix and failing suddenly wasnt covered.....but they were working on it prior to the tune......better luck on yours
Rhyder is offline   Reply With Quote
