Old 09-01-2012, 12:25 AM   #1
BonestockZL1
BonestockZL1's Avatar
Drives: 2012 ZL1 Camaro
Not to happy with my first drag strip day! :(
Went to Maple Grove tonight and ran a best pass of 12.85 at 111 with the TC on. Any other mode it just smoked the tires. Hit second on one pass with everything turned off and almost stuck it in the wall. Not to happy with how easy these tires break loose. Aired them down to 25 psi and still broke crazy loose.
The temp according to the car was between 88 and 91. I'm pretty sure there was a lot of timing being pulled out. My buddy ran a 12.90 with his lightly modified SS with stock tires. He spun way less than me. I was only leaving between 1500 and 2000 RPMs.
Looks like I need a set a drag radials. My car is a manual.
BonestockZL1 is offline   Reply With Quote
Old 09-01-2012, 12:29 AM   #2
Nemisis
Drives: 2013 Ashen Gray Metallic-M6
Practice, practice and more practice...lower air pressure a little more. Idk what the density altitude was but with air temps between 88-91 im sure that hurt as well. What was your 60'?
Nemisis is offline   Reply With Quote
Old 09-01-2012, 12:41 AM   #3
BonestockZL1
Horrible, a 2.16 Just spins. Practice makes perfect.
Old 09-01-2012, 12:42 AM   #4
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Stock tires need a lot of heat to get them sticky, but even then they are less than ideal.
You're right, you need a set of DR tires. You'll see your 60' and time decrease a bunch.
armysig is offline   Reply With Quote
Old 09-01-2012, 12:55 AM   #5
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Definately get some drag radials.
And secondly, if you're going to use the stock tires, lower the psi to 17 in them, see if that doesn't help out.
jimmy5 is offline   Reply With Quote
Old 09-01-2012, 12:58 AM   #6
Nemisis
Drop your 60' down to the 1.8x range and you'll see your time drop about .4-.5 minimum
Old 09-01-2012, 12:59 AM   #7
BonestockZL1
I'll have to try the low pressure first. DR aren't the cheapest thing for how little I am going to race the car, and air is free.
Old 09-01-2012, 01:13 AM   #8
Zee-Ell-One
YOOZ GOTA B FREKN KIDN ME
Zee-Ell-One's Avatar
Drives: 2013 6mt ZL1#826
Is it safe to run over 100mph at the end of the drag strip with just 17psi in the tires? I've never ran at a drag strip so thought I'd ask for some experienced info.
The Zeldabeast! A True Road Warrior!
2018 Dodge Challenger Hellcat WideBody 6MT
2013 ZL1 Camaro 6MT
2015 GMC Sierra 1500 SLT 6.2 L86 Crew Cab
2012 Aprilia RSV4 R
2015 Husqvarna FC450 Motomadness
First Car: 1973 Dodge Charger 340 Magnum 4MT Factory Hurst Pistol Grip Shifter
Zee-Ell-One is offline   Reply With Quote
Old 09-01-2012, 01:16 AM   #9
jimmy5
jimmy5's Avatar
Yes, it is safe.
Old 09-01-2012, 01:21 AM   #10
L99CAMA2011
L99CAMA2011's Avatar
an other guy on here set his pressure to 18 psi
Old 09-01-2012, 01:24 AM   #11
Renegade
Banned
Drives: Camaro SS Edition
Send a message via AIM to Renegade Send a message via MSN to Renegade Send a message via Yahoo to Renegade Send a message via Skype™ to Renegade
Renegade is offline   Reply With Quote
Old 09-01-2012, 05:40 AM   #12
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
You just need slicks!
rpepka is offline   Reply With Quote
Old 09-01-2012, 09:06 AM   #13
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Make sure you get a proper burnout without water(stock tires)!
sammyv is offline   Reply With Quote
Old 09-01-2012, 09:32 AM   #14
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
if you're going to drag it, why not invest in proper tires?
