09-03-2012, 02:16 PM | #1 |
Forgestar vs ZL1 wheel questions
A couple of questions.
1) Do the ZL1 black 10 spoke wheels fit an SS? (offset ok?) 2) Any idea on the weight difference between the Forgstar F14 and the ZL1 wheels? (assuming same or similar size) I really like both wheels and I simply cannot decide. I think the Forgestar are less expensive? 3) I know I said a couple but I have another question...What are the advantages / disadvantages of say running 11" vs 10" in the back and 10" vs 9" in the front? Does the wider tire provide more grip and if so does it offset what ever the extra weight difference is? Does anyone run 11" rear and 9" front. **Sigh** I am now confusing myself. |
09-03-2012, 02:27 PM | #2 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
09-03-2012, 02:35 PM | #3 |
Drives: 2016 Mosiac Black 2SS A8 Join Date: Apr 2011
I can't answer any of your questions, but I found myself going between those two wheels, because I liked the way they both look. I decided to go with the F14's and couldn't be happier. To me the F14's with the correct offset tuck in the fenders nicer.
09-03-2012, 02:39 PM | #4 |
Drives: Camaro rs 2lt IBM Join Date: Apr 2012
3,000 plus for just the zl1 black wheels, plus you have to gte the right tires.
So id got wiht F14s only because it cheaper. |
09-03-2012, 03:00 PM | #5 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
The black ZL1 wheels are lighter than the polished wheels.
I believe the black ZL1 wheels are around 27 - 29 lbs (front - back). That's right in line with the 20x10, 20x11 F14s. For comparison, SS wheels are around 32-34 lbs. |
09-03-2012, 11:43 PM | #6 |
Drives: 2015 ZL1 Join Date: Aug 2011
Im in the same boat. I also like the TSW's but they dont seem to have the right offsets for a 10" front and rear set up. What are the offsets of the ZL1 10 spoke wheels?
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
09-04-2012, 09:52 AM | #7 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
I have 10" tsw all around.
-John S.
09-04-2012, 10:06 AM | #8 |
What offset are you running? From what I've seen the fronts run too close to the strut.
09-04-2012, 08:24 PM | #9 | |
Quit being a pu$$y
In my opinion the ZL1 wheels are the WRONG offsets for our cars. Look at how far the fronts stick out.
grocerygetter did it right with the 10" TSW all the way around.
09-04-2012, 08:48 PM | #10 |
Is that a ZL1?
09-04-2012, 09:02 PM | #11 |
Drives: 2015 ZO6 3LZ Stage 2 A8 Join Date: Nov 2010
Looks like they do stick out a little... This is a member from our club. It's nothing that I would worry about though. |
09-04-2012, 09:47 PM | #12 | |
Quit being a pu$$y
Yes.
09-05-2012, 01:14 AM | #13 |
I kinda like the aggressive look of the ZL1 wheels. Currently I'm running 20mm spacers to achieve a simalir look with my RS wheels. The problem I'm having is I'm also lowered about 2-1/2" so on hard bumps the rears rub the inner fender. My goal is to run a 285/35 front and rear on a 10" wheel. I want a road race set up.
09-05-2012, 07:01 PM | #14 | |
Quit being a pu$$y
