Old 09-03-2012, 10:50 PM   #1
The Shadoww
Black on Black on Black
The Shadoww's Avatar
Drives: 2011 Camaro 1LS
Send a message via Skype™ to The Shadoww
Exclamation Removing Driver Seat
It's just the 4 tourqe screws to take it off right? I spilled my milkshake and want to clean the carpet under there lol.
The Shadoww is offline   Reply With Quote
Old 09-03-2012, 10:55 PM   #2
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
No it's only two. They are in the back just scoot the seat all the way up take off the head rest and take out the screws tilt seat forward remove harness the front are just hook that sit in the floor panel
C.an A.lways M.od A.nd R.ace O.ften
Cliffjumper is offline   Reply With Quote
Old 09-03-2012, 10:58 PM   #3
The Shadoww
You're talking about pulling the rails out too right?
I was just talking about the seat but that would provide more room. Also, how do i disconnect the plug for the wires? I can really see even with a light.
Old 09-03-2012, 11:05 PM   #4
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
There is two stits in the carpet next to the plug, pull the carpet flap up, pull on that side of the plug, you will see how the plug slides up when you pull on the side.
Very easy to do a 4yr old could do it.. LOL..
BTW it's easier to just pull the two bolts out to remove the seat..
ToolFan66 is offline   Reply With Quote
Old 09-03-2012, 11:18 PM   #5
The Shadoww
Thanks ToolFan for making me feel bad! lol. Jk. I figured it was a simple plug and play but figured id ask while i had some attention. Thanks for the help guys, I got it.
Old 04-20-2015, 11:50 PM   #6
Poogie Bear
Drives: 2012 Camaro white & blacked out
Do you know what size Torque?
Poogie Bear is offline   Reply With Quote
Old 04-21-2015, 12:03 AM   #7
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
Mine were T50
SSNYSTR is offline   Reply With Quote
driver seat, removal
