Old 09-05-2012, 11:21 AM   #1
locoycabron
Drives: 2010 Camaro SS
NGK Tr6 fouled, lean, rich or good?
What do you guys think of this cylinder 1 NGK TR6 that has been running there fo 100 miles?
Is it fouled, rich, lean or good?
locoycabron is offline   Reply With Quote
Old 09-05-2012, 03:46 PM   #2
BowlingSS
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT
Looks good to me.
BowlingSS is offline   Reply With Quote
Old 09-05-2012, 04:11 PM   #3
CFD
Drives: 2SS/RS L99 BLACK
It looks like it could be a little lean or possibly timing may be off a bit. Normally the porcelan should not be totally white, there should be a tanish color from the end where the electrode is moving up towards the end where the plug wire goes.
CFD is offline   Reply With Quote
Old 09-05-2012, 04:13 PM   #4
locoycabron
remember its been only 100 miles in there
thanks for your opinion!
Old 09-05-2012, 04:15 PM   #5
CFD
The color on the prcelan usually starts to develope rather quickly. It may be there but not visible in a picture.
Old 09-05-2012, 05:38 PM   #6
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Go WOT on the plugs, then shut the car off, and remove them (or one). Idle time will ruin the read on the plug.
pouncer72 is offline   Reply With Quote
