Old 09-05-2012, 01:01 PM   #1
locoycabron
Drives: 2010 Camaro SS
Spark plug gap
I know i should gap the plug at .40 for a no forced induction camaro but the main question is that i subcribed to alldatadiy, and the manual suggests this:
.60 GAP ????? WTF ???????
locoycabron is offline   Reply With Quote
Old 09-05-2012, 04:45 PM   #2
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
What manual did you get this out of? It should be .040".
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 09-05-2012, 04:46 PM   #3
locoycabron
alldatadiy.com
Old 09-05-2012, 11:52 PM   #4
locoycabron
anyone has the gm manual where we can see the corresponding page?
Old 07-19-2014, 05:58 PM   #5
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Reviving an old thread; my Helms manual for the LS3 calls for .060" gap as the first post states - this has to be wrong! The 90K used plug gap is .040" and the new AC Delco 41-110 plugs come gapped at .038
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold
1968 Camaro - Sold
2019 Corvette Grand Sport
obe1 is offline   Reply With Quote
Old 07-19-2014, 07:33 PM   #6
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
I have Alldata and mine says .40,don't know what info you are looking at?
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 07-07-2015, 11:46 AM   #7
Duflar
Duflar's Avatar
Drives: 2011 Camaro 2SS RS
Careful guys, there's a big difference between .040" and .40"
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=31288&dateline=1309279779 border=0 alt= />
Duflar is offline   Reply With Quote
Old 07-29-2015, 03:43 AM   #8
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
this is a old thread. DO NOT TRY TO GAP A IRIDIUM PLUG WITH A REG GAPPER. You need a special gaper. Checking the gap will wipe the iridium off the plug.
JCunningham is offline   Reply With Quote
Old 07-29-2015, 04:07 AM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
This
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 08-22-2015, 04:38 PM   #10
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Originally Posted by 1KillerSS View Post
This
The iridium will not wipe off. Tap the ground strap gently on a work bench top to close the gap or carefully use needle nose pliers to move the ground strap away from the electrode and avoid contacting the electrode. The iridium is extremely brittle and the tip can break off when even a small amount of side force is applied to the wire-like electrode. Ordinary blade type feeler gauges are fine for checking the gap. Less experienced people should stay away from the round gauges because rotating the gauge with too much pressure can cause a side load on the electrode and break the tip off.
Just livin' life
2SSCAMARO is offline   Reply With Quote
