![]() Drives: RJT 2SS/RS Join Date: May 2009
H pipes are a must
I just listened to a whole bunch of videos on youtube of h pipes and x pipes, and h pipes are definitely meaner, deeper, and throatier. Are any companies going to make a system with these?
Okie doke
You can't just go on the sound what the Xpipe or Hpipe will give you. You have to know how it will sound with your type of muffler. In one of my older cars, I had an xpipe with Chambered mufflers and it sounded like crap .. put on an hpipe and it sounded pretty good. Last car I had I put on an xpipe with straight through mufflers and it sounded better than the other car with the Hpipe and chambered mufflers ..
Crowley
Petro-sexual
Most aftermarket true catbacks will likely include X-pipes; at least the ones I've seen up to now. I don't think H-pipes are as desirable nowadays.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
Owner of Shunt
Drives: 2001 Mustang GT vert Join Date: Jun 2008
I still prefer an H-pipe on most setups. GTOs sounded a world better with a custom weldin or midpipe from StolenFox. I wish a StolenFox H-pipe was available.
Master of Medicine
Drives: 4th Gen Join Date: Oct 2008
as a "general" rule, X pipes make more power, and "generally" H pipes sound better.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
#6 | |
Owner of Shunt
and that power usually varies 1-5hp, which I can live with in making my car sound better.
example with h-pipe:
#7 |
![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
Find someone with a GTO as Jinx said and listen to the Hpipe in person. You will not care about that 1-5 HP. It sounds that MUCH better.
#8 |
![]() Drives: . Join Date: Mar 2009
Camaro comes stock with H pipe.
#9 |
Petro-sexual
Noted - thanks
#10 |
Owner of Shunt
i know it comes stock, but there isnt anything available in a larger diameter, high flow catted or non, made to fit LTs or larger diameter catbacks.
#11 |
Petro-sexual
Well, I could swear I remember the SW and Borla systems having X-pipes matching the 3-inch fore and aft pipes. I think the Texas Speed one does to; I'd have to go look, but I'm sure most companies will come with bigger pipes.
#12 |
Master of the V6
#13 |
Master of Medicine
#14 |
First off, my name is not Bud. Second, you better check your facts.
| FINAL Production 2010/2009 Camaro! (PICS) | rray200 | Camaro Photos | Spyshots | Video | Media Gallery | 799 | 05-20-2011 12:48 AM |
| 67-69 Side pipes | Thunder | 1st & 2nd Generation Camaros | 0 | 05-04-2009 04:17 PM |
| This better not happen when my camaro goes onto the dyno!!! | bluch | General Automotive + Other Cars Discussion | 9 | 04-13-2009 08:45 AM |
| Project Mako updates | Bumble Bee '77 | 4th Generation Camaros | 48 | 02-28-2009 08:01 PM |
| Removing the Cats? | ctk1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 55 | 12-27-2008 11:59 PM |
