![]() Drives: 2010 Camaro 2LT V6 Join Date: Jul 2009
Rx Iceolator and Plenum Spacer questions
What are the torque specs for the plenum spacer bolts? I am installing the manifold insulator and plenum spacer tomorrow. I know the manifold bolts are 18 lbs and the throttle body bolts are 7 lbs. But what about the plenum spacer bolts?
Also, the long manifold bolts (185mm) for the RX 25mm insulator in conjuction with the 10mm plenum spacer have little circle spacers around them (maybe 10mm thick), they seem to be made out of the material as the spacer. What is there function? is it like a washer?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace SS Brembo Brakes, Racing Brake Stainless Lines |
#2 | |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
Thank You ! I appreciate your insight. I am aware of the lack of great instructions, and wanted to consult before attempting anything.
Do I need to use gasket maker around these spacers?
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
I would, and I think others have, better to be safe than sorry.
#5 | |
You're welcome. BTW - I haven't installed one yet as I'm waiting for it to arrive. I've learned how to do it through the various threads on this forum. I would also say yes to the gasket maker. I'm just not 100% sure whether the "X-gasket" should go between the spacers and cover or between the spacers and IM. I've read somewhere here that the MACE spacers are at such a diameter that the x-gasket has actually slipped down the spacers over time if installed on top of them. I was thinking of gluing the spacers onto the cover with gasket maker first, and then assemble with the x-gasket underneath them. Of course, I think Steve at MACE has said to do away with both of the factory plenum gaskets and use sealant everywhere. So, I suppose there are multiple ways of doing it which probably doesn't necessarily answer your question... Anyway - I think you'll see how best to do it once you get into it.
#6 |
I will be using to plenum gaskets. I want to use as little sealant as possible. BTW, I am installing the Rx plenum spacer.
#7 |
Funny, the spacer I have on order is the Rx one as well. Maybe the bushing/spacers are different than the MACE ones.
#8 | |
COTW 9/16/13
Just my 2 cents |
#9 |
Just installed it, no CEL's (I pulled the battery). How long for the break in period?
#10 |
![]() ![]() Drives: 2011 1LT "Chakita". 04 Yota Join Date: Jun 2011
No break in required.
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083 |
