![]() ![]() ![]() Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
JRE tune
When you get a tune for headers do they shut off the rear sensors. I want to remove my cats for supercharger install. My supercharger won't be here for a few weeks and want to get this done now. Car is all ready tuned for headers. Thanks.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
If JRE did it than more than likely...Yes, they are turned off.
Build Journal ![]() |
Thanks
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Yes they are turned off unless you requested them to be left on. They're only there to tell the PCM how well the cats are working. They serve no purpose in tuning.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
