Old 09-10-2012, 03:43 AM   #1
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
Anyone done a oil cooler delete on L99?
Hi, just wondered if anyone done a oil cooler delete on the L99? I understand you use 12577903 oil cooler block off plate & 12553210 gasket then block off water pipes to cooler. Only reason why I'm asking is that mine is leaking & I live in New Zealand so have no warranty on vehicle & these things cost roun $750 to replace & looks like replacing o'rings & gaskets doesn't work all the time. What Ive read these coolers don't do a lot anyway. Any thoughts appreciated.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 09-10-2012, 04:53 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
you could buy an adapter, and run a standard aftermarket oil cooler. 750 sounds awfully steep for a factory intercooler. sounds like price gouging from your dealer / importer.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 09-11-2012, 05:36 AM   #3
Kiwi_Camaro_2010
Sounds like an idea, I'll have a look around for an adapter to suit L99/LS3 block to aftermarket cooler. cheers
Old 09-11-2012, 11:01 PM   #4
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Drives: 2011 Camaro SS/RS M6
Would not recommend just blocking it off. LPE has an adapter kit to use a standard fluid cooler http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Product_Code=L300025297&C ategory_Code=C186&Store_Code=LPE
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads
New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs
MaxKamai is offline   Reply With Quote
Old 09-11-2012, 11:23 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I wouldn't delete it either but maybe a "better" more "efficient" cooler?
Old 09-11-2012, 11:29 PM   #6
pouncer72
Send a message via AIM to pouncer72
Mine's blocked off. Tens of thousands of LS engines dont have them, and the factory one sucks. Unless your road racing, I wouldn't bother with one at all.
pouncer72 is offline   Reply With Quote
Old 09-11-2012, 11:31 PM   #7
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
You will still need to modify a couple things.
1. You cap off the coolant fitting to the block (Blue Circle) and replace the factory t (Red Circle) in the upper rad hose with a straight connector.
or
2. You add a 90* hose fitting @ Blue Circle and adapt it to factory coolant hose @ Yellow Circle
I would probably recommend option 1 as it seems to be a little more simple and I don't know if you would have any clearance issues with option 2.
Hope this helps and I didn't make it more confusing.
Old 09-12-2012, 01:09 AM   #8
Kiwi_Camaro_2010
Hey thanks guy's for the info, think I may go with MaxKamai's & ipouncer72's idea & block plug block & put straight connector in, I have blank plate & gasket coming, just have to find out what size bung (15) for the block I am going to need & dia of connector pipe I will need. The less clutter the better for me.
Old 09-12-2012, 11:16 AM   #9
pouncer72
http://texas-speed.com/p-233-gm-large-coolant-plug.aspx
The block plug
Old 09-12-2012, 08:35 PM   #10
Kiwi_Camaro_2010
Originally Posted by pouncer72 View Post
Hey thanks!!, dam Ive ordered wrong one then, thought i had picked the plug as GM 11609289 oh well spares
cheers
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Old 09-12-2012, 08:39 PM   #11
Kiwi_Camaro_2010
well I won't be ordering it from Texas speed, just checked freight cost for this to New Zealand, they want $94US to ship, think thats way out of wack!
Old 09-12-2012, 09:23 PM   #12
pouncer72
You can order it from any gm dealer. The part # is listed on their website.
Old 09-12-2012, 10:24 PM   #13
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I deleted mine on my LS3. I do have to thank pouncer72 as the inspiration for it. So far, no problems in the 90+ degree heat but I haven't been running the car hard either.
Old 02-15-2013, 01:42 PM   #14
Mike2ss
Airborne Pathfinder
Mike2ss's Avatar
Drives: Camaro ZL575
I just came from my dealer doing an oil change and I talked to one of the techs and I ordered the three parts and they will do the delete next week for me once the parts arrive. I believe around 25 dollars for the parts.
2010 Camaro Indy 500 Pace car, LS3-ZL575
Other cars are- 95 BMW 325 sedan- AA exhaust, AA CAI, AA Strut bar, AA chip, M3 rotors and calipers, racing clutch, oversized injectors, upgraded M3 interior- Audi A4 SLine, with black out optics
Mike2ss is offline   Reply With Quote
