Old 09-12-2012, 10:19 AM   #1
BowenSS1
BowenSS1's Avatar
Drives: She totaled it!
How do you tell if you have belt slip on maggie?
Just as the title states how do I detect if I have belt slip on my maggie.
I do not have a boost gauge...can it be seen on dyno chart?
BowenSS1 is offline   Reply With Quote
Old 09-12-2012, 10:36 AM   #2
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
If the dyno is equipped with a boost gauge then yes. The tuner should also be able to see if you have belt slippage by looking at his scanner while doing WOT pulls if he knows what to look for.
Chris
Chris-HPS is offline   Reply With Quote
Old 09-12-2012, 12:29 PM   #3
Jessika
Drives: Anything Blown
You can get a cheapy mechanical boost gauge,
plug it to the boost port on the manifold
tape the gauge to the windshield
& drive.
How much boost do you suspect you are producing?
Jessika is offline   Reply With Quote
Old 09-12-2012, 09:21 PM   #4
BowenSS1
BowenSS1's Avatar
Im only making 9lbs...just a thought i had while @ work...u
I mean common sense tells me the pulley should make "X" amount of boost and just monitor boost gauge....but I dont have one...So there is no visual signs of belt slip to look for ...It was just a thought. Thanks
Old 09-12-2012, 09:42 PM   #5
Supercharged SS
Drives: 2010 Camaro
Do you log your car? I log my manifold pressure using SCT. Just recently learned that I have real bad belt slip. On the initial hit I only make 11, it hangs around 13 from 2nd gear through third then finally gets near the mid 15's. I hope the belt is stretched. It's been on all season. It use to get up to 17 psi. I can see it in my 60's. They went from 1.44's to 1.5's. New belt is on and ready to log. This is the last chance with the Maggie. I'm about to switch blowers.
Old 09-12-2012, 10:01 PM   #6
BowenSS1
BowenSS1's Avatar
I did log with livewire... But didnt have a clue what I was looking at....I did the list and steps that Ted recommends while logging for him..
Old 09-12-2012, 10:05 PM   #7
chappy48
chappy48's Avatar
Drives: 2010 Camaro Auto 2SS/RS
Ahhhh! Don't say that lol. Hopefully I'm good. I'm only at 12psi right now.
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined.
Jannety Racing forged 416.
TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive.
Jannetty Racing Rough Idle Cam, LS3 Conversion.
Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles.
ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback.
Custom 18" Forgestar F14's, Nitto 305/45-18 DR's
chappy48 is offline   Reply With Quote
Old 09-12-2012, 10:06 PM   #8
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
That's pretty impressive for that little 'ole thing.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 09-12-2012, 10:06 PM   #9
Supercharged SS
Drives: 2010 Camaro
You need to select the pid that's labeled absintkman. Or something similar. That's boost. It's measured in kpa. I have the conversion chart if you need it. 100 is 0 boost. Above that is boost, below is vacuum. It's great to watch. Pretty interesting.
Old 09-12-2012, 10:07 PM   #10
jrpxxii
jrpxxii's Avatar
So you finally wanna go fast
Old 09-12-2012, 10:07 PM   #11
Supercharged SS
Drives: 2010 Camaro
That's about it. Need to go 10 rib but I'm gonna go to the 4.0 whipple.
Old 09-12-2012, 10:09 PM   #12
Supercharged SS
Drives: 2010 Camaro
Is your car done yet? I measure you completion by moons!!
Old 09-12-2012, 10:12 PM   #13
Jayrcr3
Jayrcr3's Avatar
I see 8's in your future.
Old 09-12-2012, 10:15 PM   #14
Supercharged SS
Drives: 2010 Camaro
I wish. I'm still hunting another 9. This blower isn't cooperating so it's gotta go.
I only want 8-850 rwhp. Nothing close to what the fast cars make.
