Old 09-14-2012, 02:20 PM   #1
VAbdul
VAbdul's Avatar
Drives: '10 Camaro SS
Installed Axleback, Want to remove resonator on L99, how?
How should I go on about removing the central resonator on my L99? I have a Borla S Type Axleback installed and I am ordering a Magnaflow True-X (X-Pipe). I'll need extra piping correct? Is the resonator cut out? Or removed from behind the cats?
UPDATE:
I went to 2 exhaust places and they both said they'll need about $300+ dollars to do it (2 and a half hours + the price for the pipes) now I don't understand why that's the case, I asked them to lift the car and they did so I can explain what has to be done.
They told me they need to remove the resonator, cut the middle part out, weld the new x-pipe with their pipes, and re-install it along with the axleback.
I think I'll just go somewhere else or will probably ask them to replace my resonator with pipes, period (no x-pipe)
what do you guys think?
VAbdul is offline   Reply With Quote
Old 09-14-2012, 07:46 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I did this mod also, we cut out the big ole ugly resonater right where the tubing goes in the front and comes out the back of it, then welded the xpipe to where the front of the resonater was attached to the tubing then ran extensions from the back of the xpipe to the rest of the rear tubing. I would take a pic but it is dark out now.Good luck
Old 09-14-2012, 08:58 PM   #3
TheNewCzar
Drives: 2011 SS Rally Yellow Vert, 2000 WS6
Get some Stainless pipe and have a muffler shop cut out the chamber of horrors, weld the X up front and pipe behind it.
TheNewCzar is offline   Reply With Quote
Old 09-15-2012, 08:39 AM   #4
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Decent muffler/exhaust shop should have no trouble doing it for you.
Make sure to shop around for prices.
I needed a small section of exhaust switched out and one local exhaust shop wanted $180 (their minimum charge) to do it.
So I went to an tranmision/exhaust shop near where I work and they did it for $40.
Old 09-15-2012, 01:00 PM   #5
Juiced1
Drives: 2012 2SS CAMARO 45th
+1 Some people want huge mininum charges. Others places will take cash on the side.
Juiced1 is offline   Reply With Quote
Old 09-17-2012, 09:05 AM   #6
Hired Gun
Wild Man
Hired Gun's Avatar
Drives: 2010 Camaro
I am having this same exact thing done Saturday. I am running LT headers and GMPP axel back. I also ordered the Magna Flow X pipe.
2010 Camaro Black with White Stripes, Jannetty Racing Roto-Fab CAI, VMAX Ported Throttle Body, Long Tube Headers, GMPP Axel Back, Emblem Pros Custom "VOODOO" Under hood Bow tie, Chrome Gill Inserts, HUD plate, Sparks Performance White SS front and rear Plate MPD-1 Spoiler
Hired Gun is offline   Reply With Quote
Old 09-17-2012, 10:04 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I also recommend the magnaflow true x pipe but there are also a few resonator replacement X pipes that have all the piping you need built into the X pipe. Just cut the resonator out and clamp the X pipe in.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 09-17-2012, 10:34 PM   #8
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
I paid $40 to have my x-pipe welded in with the resonator moved as well as welding on my pype's bomb axle back shortly after buying my car... I have since ditched that setup for a full Doug Thorley exhaust, headers to tips... but just ordered Dynomax Race Bullets to replace the DT mufflers, which I find to be too quite(2-chamber) and a little raspy...
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 09-21-2012, 01:46 PM   #9
VAbdul
VAbdul's Avatar
Old 09-21-2012, 02:04 PM   #10
RyanBoles
RyanBoles's Avatar
Drives: 2010 2SS
You may lose some torque with no x or h
RyanBoles is offline   Reply With Quote
Old 09-22-2012, 02:39 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Go some where else, 4 cuts, 6 weldsand aboue 3 feet of tubing and 30 minutes cost me 100 bucks..Good enough for me.Oh, and the entire system DOES NOT have to come off to do it, as it looked like they were saying in what you posted..
Old 09-22-2012, 06:36 PM   #12
VAbdul
VAbdul's Avatar
How would they do it if they don't have to remove the whole thing? Just make the cuts, place the pipes, and weld it while the car is raised?
Old 09-22-2012, 06:45 PM   #13
RyanBoles
RyanBoles's Avatar
Drives: 2010 2SS
Yep!
Old 09-22-2012, 10:05 PM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Exactly that..
