Old 09-19-2012, 12:16 PM   #1
thasleeper
thasleeper's Avatar
Drives: 2010 Camaro 2 SS/RS\ CYBER GREY
Rollstop Kit
After reading camaro performers magazine. I ran up on rollstop kits. It's seems like something I need. I get so annoyed coming off the line slow, low rpms and redline.
How many 5th Gen done this mod ? Also, if so did you think its a good idea to go ahead and add a reservior to separate the brake and clutch fluids?
thasleeper is offline   Reply With Quote
Old 09-19-2012, 01:31 PM   #2
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
I use the SJM line lock. It helps keep the car from rolling out of the beams at the drag strip if needed. But mainly I use it on the burn out before a run, I have a manual tranny, makes life so much easier.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 09-19-2012, 01:57 PM   #3
thasleeper
thasleeper's Avatar
Ok! This sjm line lock sounds similair to the rollstop.
Old 09-19-2012, 03:45 PM   #4
TornadoSS
WICKDSS
TornadoSS's Avatar
Same thing. SJM, Hurst roll control, etc.
I also run a separate clutch reservoir, it helps the sticky clutch issues.
