Old 09-19-2012, 12:58 PM   #1
zer0ss
zer0ss's Avatar
Drives: 2012 Camaro V6 LFX
Remote On Trigger for an Amp question
I've worn out the search button looking for this answer before going to google and I'm looking for confirmation. For my set up, I am splicing into the rear speakers and running it into an amp with speaker-level input with bridgeable 4 ohm out, to power 2 paralleled 8 ohm subs.
The "remote on" is basically a signal sent to the remote on input of the amp to tell the amp to turn on using the input to the power input terminal (which is ~12V) - is the "remote on" a 12V signal as well?
If so, instead of removing the head unit and accessing the remote enable pin of the radio, couldn't I wire a toggle switch from the battery to the cabin and to the "remote on" of the amp?
I know that with this solution the potential danger is to leave the remote on toggle in the on position and kill the battery - but I am attempting to avoid removing the radio.
Is the 12V outlet in the console only 'hot' with the engine running? If so, I could tap that and avoid the use of a toggle - but I would like to have control of the subs in the cabin.
Darkheart Build thread
Mods: CAI Intake w/ Scoop and Rotofab WW Relocation, MRT v2.0 Exhaust, RX Catchcan and Ported TB
Appearance: AAC Ghosted Side markers, Plasti-Dipped Bezels and 'Beauty Rings', Fully Debadged, Tinted Tail Lights and Reverse Lights
Sound: Two 12" Kicker Comp Subs in ******** Enclosure
zer0ss is offline   Reply With Quote
