Old 09-26-2012, 08:07 PM   #1
SmokedSS
Guest
Drives: 2011 2SS / RS A6
Lower IAT's help
I am wanting to lower my IAT's and have read all the threads I can find. I have a few questions for the experts or those of you that are actually using these products. I am running a maggie @ about 10-12lbs of boost and my IAT's stay around 40 above ambient temp. Super Chiller or a good dual heat exchanger? I am not looking to tune for lower IAT's but want the best option for protecting my engine and preventing detonation or timing being pulled due to heat soak.
SmokedSS is offline   Reply With Quote
Old 09-26-2012, 08:17 PM   #2
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I love my Chiller, AI or RX is fine, pretty much the same set-up. I see 30-40* drop from without the chiller.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 09-27-2012, 07:48 AM   #3
SmokingSS
Drives: 2011 2SS L99 RS
Turbo99
I have read isolated issues with AC belts and clutchs.. What's your experience with that? I am currently looking for a shop in Lousiana to hook me up...
SmokingSS is offline   Reply With Quote
Old 09-27-2012, 08:38 AM   #4
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
Interested also. But I'd live to hear the differences between the 2 different A/C cooler systems.
Pros/cons of both.
2011WhiteSS is offline   Reply With Quote
Old 09-27-2012, 10:39 AM   #5
SC2150
No issues with belts or compressors any different than stock. I would be interested in a link to where you read of issues as we ship or install nearly a kit a day now and have not heard of any.
We are doing install specials here where they are built or there are shops around the country that can do it as well.
Here are the advantages:
only adds app 12# total weight (every 100#'s is a tenth in the 1/4 mile).
Always cooling any time the AC comp is engaged so better for the entire blower/components as heat kills.
Never need to buy any consumables so no reacurring costs like meth, ice, etc.
Competition mode is for track use as it shuts off the cabin CA so no moisture is being extracted to leak on the track and puts all freon through the chiller.
Install and forget about it. If the AC is off or the compressor fails it automatically defaults back to the HE.
20-50* F below ambient air temps.
Your car will pull timing at 115* IAT's and at 150 it is pulling 5-6* and at 180 as much as 8-10* and thats a TON of power lost.
Anyone in the state can stop in and see one operating in person here.
Old 09-27-2012, 11:12 AM   #6
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Will you pm me a price on one of these kits. How long does it take you to install them. Thanks!
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 09-27-2012, 11:18 AM   #7
Turbo99
Turbo99's Avatar
I have had to replace my clutch but as Tracy said its not because of the chiller, you do need some specific tuning to have the a/c controls turn off for WOT and depending on what HP is going to determine how fast your car revs, this is where the clutch will have issues the faster the rev the more the a/c clutch will slip when it disengages but the best practice is to turn it of right before you run at the track. For the street you will be fine for normal driving and some exceleration but you will put the same wear as you would with just the a/c on.
Old 09-27-2012, 12:08 PM   #8
SmokingSS
Anybody installing near Baton Rouge?
Old 09-27-2012, 01:10 PM   #9
SC2150
Let me see who we have there.
Turbo99 has maybe the most use on one to date and has done dyno and dragstrip as well as street logging.
Old 09-28-2012, 12:04 PM   #10
SmokedSS
Guest
Thanks for the help...Just found a great deal on the forum on a used / new AI Super Chiller never installed... Now I need an Installer!!!
Old 09-28-2012, 05:51 PM   #11
old motorhead
Drives: Maggie blown LS3 vette
If you stay at 40 over ambient at cruise or when you're out of boost, you have other issues.
old motorhead is offline   Reply With Quote
Old 09-28-2012, 08:00 PM   #12
SmokedSS
Guest
old motorhead... explain please.. on a 95 degree day I stay aroung 130 IAT driving normal (may dip down to 120's cruising)...Are you saying I have a problem?
Old 09-28-2012, 08:41 PM   #13
Turbo99
Turbo99's Avatar
That is alittle high for cruising but nothing silly high. I see about 15* above ambient with out the chiller.
Old 09-28-2012, 09:04 PM   #14
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
what kind of problem... mine is really hot im running like 150 on my whipple goine down the road at 75 mph... 416 with 10 rib setup..... maybe i need to drain coolant and run water wetter??
Whipped416 is offline   Reply With Quote
