Old 09-27-2012, 12:28 PM   #1
PeeBee
PeeBee's Avatar
Drives: "Bee" ZL585, Dark Blue Suburban.
Fourth gear flat out acceleration - can't shift to 5th
OK... Maybe this is normal, maybe not...
Been on the autobahn a few times, and had it several times.
During flat out acceleration in fourth, the clutch pedal literally goes down, and I can't shift from 4 to 5 (trying to do so, it feels like it is going straight into 3rd).
Anyone else experienced this? Is this "behavior" normal?
PeeBee is offline   Reply With Quote
Old 09-28-2012, 08:18 AM   #2
djamphi555
Drives: Camaro 2010
That does not sound right. Trying to accelerate after reaching 160km/h does not work well at all in 5th gear for me. 5th gear is more like overdrive just maintaining the speed. However, I can flat out accelerate all the way to around 215km/h in 4th gear. This is where I upshift to 5th. 5th goes in smoothly and my clutch pedal does not go down on its own.
djamphi555 is offline   Reply With Quote
Old 09-28-2012, 08:39 AM   #3
Chevrolet Customer Svc
Drives: GM Vehicles
I would recommend going to a dealership if you think this may be a recurring issue. Please let us know what the outcome is!
Brandon
Chevrolet Customer Service
Old 09-29-2012, 02:22 PM   #4
PeeBee
PeeBee's Avatar
I'll ask my dealer to have a look at this when the crank flywheel gets replaced...
Old 10-01-2012, 02:31 AM   #5
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
Same issue here, although it doesn't occur frequently... Getting into 5th at 140+mph on the Autobahn seems to be a matter of luck, no matter what shifting technique used.... Even a ZR1 clutch doesn't seem to like that, the pedal goes light during such kind of runs
It feels like the transmission is blocked at times - synchros maybe?
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
