Old 09-27-2012, 03:35 PM   #1
camarokc
camarokc's Avatar
Drives: Victory Red 2013 Camaro 2LT/RS
Raising the top speed
I am getting the 2013 2LT camaro with the RS package. I'm going to get new rims and Y-rated tires. Can I raise the limited speed on the governor? What is the actual top speed of the vehicle?
camarokc is offline
Old 09-27-2012, 03:36 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
If your getting the RS package the top speed on the limiter is 156. I don't see why you'd need to raise it more than that but yea it can be done. It can only be done through a tune though.
lscamaro is offline
Old 09-27-2012, 03:41 PM   #3
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
It won't be nesessary.....as stated above, its set at 155 mph......the tires that come on it are Y rated.....and you V6...on a track, flat out....with enough flat straight open road will top out around 148ish.....so you will never see the limiter.
Sir Nuke is offline
Old 09-27-2012, 03:44 PM   #4
Jameg1011
Jameg1011's Avatar
Drives: 2012 2LT 45th anniversary
It won't be necessary.....as stated above, its set at 155 mph......the tires that come on it are Y rated.....and you V6...on a track, flat out....with enough flat straight open road will top out around 148ish.....so you will never see the limiter.
This ^
But I'm curious as to why you would like to travel over 155mph anyways.
Jameg1011 is offline
Old 09-27-2012, 03:44 PM   #5
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline
Old 09-27-2012, 03:46 PM   #6
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
And as I recall, even though the roads in Oklahoma are flat and straight, they're not exactly smoothe.
My VIN = 2G1FK1EJ9A9105017
CamaroSkooter is offline
Old 09-27-2012, 03:47 PM   #7
PeeBee
PeeBee's Avatar
Drives: "Bee" ZL585, Dark Blue Suburban.
Because it's FUN
PeeBee is offline
Old 09-27-2012, 06:13 PM   #8
My45thAnniversaryCamaro
My45thAnniversaryCamaro's Avatar
Drives: 45th Anniversary
Originally Posted by PeeBee View Post
Because it's FUN
Very very fun
45th Anniversary
MRT v2.0
CAI
My45thAnniversaryCamaro is offline
Old 09-27-2012, 06:28 PM   #9
Dznts
Anabolic Connoisseur
Dznts's Avatar
Dznts is offline
Old 09-27-2012, 06:30 PM   #10
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Void the powertrain warranty just to increase the top speed?
slick rick is offline
Old 09-27-2012, 06:30 PM   #11
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
How do they configure speed rating for tires? I have had a set of Bfg radial t/a's running 165+ down the high way (only rated to 118)
https://www.youtube.com/@FredJrsGarage
‘19 Silverado 3500 dmax
‘77 trans am
‘63 c2
Shopping for more Camaros
Vroom_vroom is offline
Old 09-27-2012, 11:49 PM   #12
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
ZWA SS is offline
Old 09-28-2012, 12:13 AM   #13
Parag
Drives: 2010 camaro 2SS LS3
it is a safety issue for sure, but is more that tires are not rated for higher speeds because it cost alot to test them at those speeds. and a non performance tire is just a waste to pay for all the testing.
the tires usually do just fine. it is also a stretching issue on low ply tires. they will expand and decrease the patch size. very dangerous at high speeds
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline
Old 09-28-2012, 01:16 AM   #14
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Speed ratings are determined by the tire industry and then tire engineers rate them according to the construction of that particular tire and tested at a certain speed, temerature and duration.
Most things that have a safety rating also have a safety margin built in. You should be able to exceed the rating for a short period under the right circumstances.
I have, as of today orbited the sun 55 times. When I was 18 and had a '68 SS I went about 150 mph a couple times on bias ply tires. They didn't use speed ratings back then that I know of and bias ply tires would not have been rated for anything near 150. If I had known that, I may not have done it.
Tires will go as fast as you want until they give up at which time you will know the limit for that tire.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline
governor, limiter, top speed
