10-02-2012, 05:45 AM | #1 |
Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
DRL not working
Hey guys,
So I have the old P13W plasma from ACC and one of them just went out. is that happened to another person? What are you guys using nowadays? I want to get new bulbs that match the halos better. please send me any suggestion. I still have to check the connection
10-02-2012, 06:13 AM | #2 |
knows 2 facts about ducks
The regular p13w bulbs match the halos better. Downside is that they can burn out due to the PWM
10-02-2012, 10:45 AM | #3 |
Ok sooo today just now I checked the DRL and they both work.. but this morning it didnt.. but it was dark so the halos were one... So to double check I turn the halos on and then that one DRL would not be on.. So do you guys thing that my Ttap cable disconnected or something went wrong with it?? I mean both DRLs work on the auto mode during the day but then turn the know one click to the right and one doesnt.
10-02-2012, 11:05 AM | #4 |
I would just double check your connections. Might be a loose wire or something.
10-02-2012, 11:15 AM | #5 | |
10-02-2012, 03:07 PM | #6 |
ok I will look at it maybe today later today.. thank you guys
10-03-2012, 07:21 PM | #7 |
So I checked today the connection becauase the DRL stopped working again.. and everything seems fine and connected right.. however, if I shake all the cables the light kinda stops working.. idk whats wrong with it.. I have no idea how to fix it.. made sure the Ttaps were good and all the way in.. I need to tak a closer look at the connections but I want to remove the bumper for that so itll be a while..
10-03-2012, 07:53 PM | #8 |
Drives: 2012 Corvette GS Join Date: May 2012
Wuiquen...can you remove the t-taps, tape the wires up and get a DRL harness? A vendor has one for $50...it goes in between the OEM harnesses...no wire tapping or splicing...or worries about loose connections...and your DRLs on at night. Isn't that worth a little peace of mind?
