![]() Drives: 1LT RS Join Date: Oct 2011
RPMs sometimes drop to 400 while stopped
I have a 2012 LT manual and sometimes when I'm stopped at a light the RPMs will dip to about 400 for a second or two then pop back up to the regular 800 or so. The engine makes a slight shuddering sound at the same time. It happens when I'm in neutral or in 1st with the clutch in (I think), but always while the car is not moving. Dealer says they don't know what the problem is
Anyone have this issue? Thanks |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service
#3 | |
![]() Drives: 2010 Camaro SS Join Date: Mar 2010
mine does exactly the same thing. PM sent to you, Thanks, Ron Tilley |
![]() Drives: 2013 Victory Red LS 6 Speed Manual Join Date: Oct 2012
I just bought mine 2 weeks ago, very happy however I have a similar issue. When it's idle at a stoplight there's a shudder that feels like the car's going to die and the rpms show a quick spike I thought it was bad gas but I am on my third tank. Anyone else have this?
![]() Drives: none at this time Join Date: Aug 2009
i may be able to shed some light on thisfor ya'll ihada88 regalcoupe thatdid the same thing rpmswoulddipwaylowandbackto750 or sothen backdownor wouldrevup to 1500andgo back to 750-800rpm when i had the cari wastold to pull the main fusesunder the hood andleave themoutfor amin or so then put thembackin anddrive the car25 miles to re set the ecm seemed to word as only had to do it once and car ran fine after that keepin mindthe regal had 160,000plus miles on it to but other then the weird idle ran greatotherwise returning 23-27 mpg good luck and hope this helpsya'll some
#6 |
Actually I checked this morning on the way to work and my problem is the same as yours. Is 400 too low? mine is closer to 500 and then it will shudder and kick up but goes right back down to 500rpms. It's not really that frequent and it isn't usually that strong but I just don't know if its common and not anything to worry about or if it's a defect
#7 |
![]() Drives: 2013 1LS - Victory Red Join Date: Nov 2012
sorry for the thread necro, but did you guys ever figure this one out? i have a 2013 LFX with only 5800 miles on it, and it's been doing this for awhile. since i hardly ever drive the car i haven't yet bothered to bring it to the dealer to look at it, but it's exactly as you describe. when the car is stopped and idling, it will occasionally drop RPM from about 600 to 400, shakes a litte and sounds like it's gonna die, then spike rpm to 1200, then drop back to 500 steady. i'm fine with this if it isn't hurting the car, but feeling like your car is gonna die at a stoplight is really annoying.
#8 | |
William R. Chevrolet Customer Care |
#9 |
![]() ![]() Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
pull your intake tube off and check your intake to ensure it is clean and the throttle plate is opening and closing without any sticking. Change your fuel filter and air filter. Check your fuel preassure at idle. Try the fuse pull to reset things. Thats my 2 cents
| Tags |
| engine issues |
