Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Motorsports Discussions
Old 10-05-2012, 09:12 PM   #1
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Going to my first WOW at Miller Motorsports Park
I finally got up the nerve to sign up for WOW next week. Any suggestions for maximum fun factor? Is one track better than the other for a first timer?
Sent from my DROID BIONIC using Tapatalk 2
Retro69 is offline   Reply With Quote
Old 10-10-2012, 12:32 PM   #2
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Congratulations! You're going to have a really great time! We have a team garage at Miller, and while we haven't had too much time to race this year it's absolutely one of the best tracks in the US.
Just relax, and be sure to take any opportunity to take an instructor with you as a beginner. If this is your first track event don't get caught up trying to keep up with anyone else. If this is your first track day that Spec Miata really IS faster than you are with 1/3 of the engine output.
Any of the track configurations is going to be a blast for your first time out! Just keep your ears open and your attitude positive and you're going to be hooked for sure!
Old 10-10-2012, 08:39 PM   #3
Retro69
Retro69's Avatar
Got to run both circuits. So far having a blast. Thought I had a little brake Fade on the east circuit (yikes!) Here goes another lap on the west.
Old 10-10-2012, 11:15 PM   #4
Retro69
Retro69's Avatar
Only got to run the west circuit once more. (Dang short autumn days :( )
For lack of something better to judge my performance I reset my average speed gauge at the start then recorded it at the end. Probably not very accurate but I did improve my west circuit run from 43.2 mph avg to 53.9 on my second run. Feel pretty good about that.
I mentioned previously that I thought I had a little brake fade on my east circuit run. Doesn't seem to me that I should have that happen on that short of a run (2.2 miles I think. I was running a straightaway pretty hard into a sharp left turn and was laying on the brakes pretty hard. I'm sure my inexperience is a major factor. If I'm going to be running the track in the future perhaps slotted, cross drilled rotors need to go on the wish list.
Sent from my iPad using Tapatalk HD
Old 10-18-2012, 07:12 PM   #5
PfadtRacing
East track doesn't have the big straight like full or outer loop does, but you can pick up quite a bit of speed coming into clubhouse. The fade is likely a little inexperience, but if you haven't swapped out to a quality brake fluid, pads and rotors there certainly are some improvements that can be made even for folks with a ton of track time.
One point of advice, avoid drilled rotors for track use. Typically the holes in drilled rotors are (predictably) drilled into the rotor after it's been cast, which can cause cracking with hard use. IF, and this is a big if, you see rotors with holes at the track they were likely either cast as part of the rotor, or it's a car that doesn't see a lot of track time.
A couple small mods and your car can be a WHOLE lot of fun out there. If you haven't connected with Jordan at JDP Motorsports he spends about as much time at Miller as any Camaro owner, and is a great resource for parts and advice. We can definitely help you with quality suspension components as well.
Old 10-18-2012, 08:07 PM   #6
Slowkray
Slowkray's Avatar
Drives: 2010 Camaro 2SS/RS M6 IOM
That is awesome Retro69. I have run my car at Miller quite a few times. It is nothing but pure addiction. Glad you had a good time. Hope to see you out there next year, or maybe wintercross.
Slowkray is offline   Reply With Quote
Old 12-01-2012, 12:26 AM   #7
Albert15
Banned
Drives: Camaro 2007
That nice and congratulation for you to take participate at racing park. I hope you will be enjoy lot.
Albert15 is offline   Reply With Quote
Old 01-24-2013, 12:24 AM   #8
RayTheRat
Goofy old fart,salt racer
Drives: 2010 Camaro 2SSRS: making progress!
If I can get my Monte Carlo into the 150 Club (gremlins have plagued me for the last coupla years) I'll take the skinny salt flats tires off and put some sticky ones on and then we'll see how WOW works out. I may pull the TH200-4R out and replace it with a Tremec 5-speed.
I plan to run my Camaro in the 130 Club on the salt this year, too. Ohh, yeah. And do the photography for landracing.com, too. Could be a little interesting. But I love it.
RayTheRat is offline   Reply With Quote
