Old 10-08-2012, 04:09 PM   #1
Camper
Banned
Drives: 10' 2SS LS3 M6
Cam Install and a Melling Oil pump?
so... I've been pulling some pricing on a full cam install with all the supporting mods and i've now had 2 installers recommend sticking with my stock oil pump over the Melling. Is this legit or ??
Camper is offline   Reply With Quote
Old 10-08-2012, 04:32 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
They could be lazy! Your the customer and my advice would be to get it and have piece of mind. Just my .2
Ask them why not.
Old 10-08-2012, 05:26 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
my shop said same thing. it is rare of it to fail. still can though.
Old 10-08-2012, 06:02 PM   #4
Camper
Banned
here are his exact words
"I highly recommend keeping the factory oil pump on the car, the Melling unit is not going to improve performance and in a few cases we have seen the oil pressure too high on them(60-70psi at idle)"
Old 10-08-2012, 06:06 PM   #5
SC2150
Go with the melling. Excellent pump and with it all torn down for the cam now is the time to do it.
Old 10-08-2012, 06:08 PM   #6
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
If they do the job right a new oil pump isn't needed. I kept the stock pump in mine and my oil pressure never drops under 30
IDEALG is offline   Reply With Quote
Old 10-08-2012, 06:09 PM   #7
Camper
Banned
ok... its all tied up 2-2..
you guys are suppose to make this easier for me!
Old 10-08-2012, 06:13 PM   #8
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
I put the Melling in mine and have had NO issues and the slightly higher pressure is welcome at the higher RPM's and oil temp. You might also consider the LS3 stock pump has been known to have problems with a sticking relief valve that has caused more tan one person on here to replace an engine. Since you are doing a cam install, your engine warranty will be out the window if the stock pump lets go. For that reason alone, I would put the Melling in.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 10-08-2012, 06:14 PM   #9
RxDoc08
Jason
RxDoc08's Avatar
Drives: 2011 2SS/RS M6
Ted Jannetty told me to stick with the stock pump. His philosophy was that if it isn't broken, why fix it?
RxDoc08 is offline   Reply With Quote
Old 10-08-2012, 06:29 PM   #10
G8RAM
Drives: 2009.5 G8 GT
Isn't broke yet!!!!
I did tons of research on this issue and decided to step up to the quality of Melling.
It's really worth the piece of mind too. Just my 2 cents...........
At the end of the day you're the one that has to take the risk.
G8RAM is offline   Reply With Quote
Old 10-08-2012, 08:08 PM   #11
Dallascam
Dallascam's Avatar
Drives: 2010 2SS/RS
I just recently had Cam install done by a performance shop that does a lot of this kind of mod. I asked him several times about changing the oil pump, and He told me that the stock oil pump was as good or better than anything out there. I stayed with stock, and have had no problems.
Dallascam is offline   Reply With Quote
Old 10-08-2012, 08:31 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^^ clueless shop to say that it's better than a melling^^^
Just saying.
Old 10-08-2012, 08:38 PM   #13
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
Get the Melling and be done with it.
ITGuy11 is offline   Reply With Quote
Old 10-08-2012, 08:53 PM   #14
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Look at me! 2010SS early build, stock pump seized, shredded the motor in a matter of seconds! In the works to be rebuilt, well it's rebuilt just waiting on the install! Price, $9500!!!!! All new internals, forged of course! But I didn't listen to my shop and said the stock pump will be fine! Getting the melling pump this time!
But really I believe the problem was with the early 2010's! I would go with the Katec timing chain also!
csjcsj is offline   Reply With Quote
