Old 10-09-2012, 03:24 PM   #1
lspower62
lspower62's Avatar
Drives: 2010 White 2SS m6
Cleaning Intake Manifold Of Oil
Hey guys so after reading all the horror threads about oil in the intake and catch cans I ordered myself an RX catch can (instantly). So this solves further oil in the manifold. But what can I do to clean out all the oil just sitting in there. I was thinking seafoam, but is it really that effective? I took a peek and there is quite a bit in there and I only have 12k miles. should i be worried?
lspower62 is offline   Reply With Quote
Old 10-09-2012, 03:27 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
No imo you shouldn't be.. I had a little bit and got the catch can the same time as you...idk if its safe for the v8 manifold to do this but I soaked my manifold in simple green...rinsed and let it dry
Lil' Nasty is offline   Reply With Quote
Old 10-09-2012, 04:04 PM   #3
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Just wipe out what you can, at least that is what I did.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 10-09-2012, 05:04 PM   #4
lspower62
lspower62's Avatar
ok thanks guys didnt want to loose sleep over this.
Old 10-09-2012, 07:51 PM   #5
asrautox
Drives: 2017 SS 1LE
It is terrifying isn't it. Rest assured though, the RX can is one of the best at removing all the scary oil.
asrautox is offline   Reply With Quote
Old 10-09-2012, 09:26 PM   #6
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
Talking
I put my Vmax throttle body on shortly after I put the RX can on and while I was changing throttle body I took a rag and sprayed it with throttle body cleaner and used a stick to reach in there the best I could and cleaned it out! Mine wasn't that dirty and I got very little out of it! Good luck!!!
The Blue Ox is offline   Reply With Quote
Old 10-29-2012, 07:59 PM   #7
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
What would happen if the throttle body stuck open when accelerating?
edog is offline   Reply With Quote
Old 10-29-2012, 08:01 PM   #8
lspower62
lspower62's Avatar
You would keep accelerating?
Corsa Cb, RX catch, Vararam, LT Headers catless, slowhawk tuned, 20% tint, hks1inch lowering springs, zl1 20x11 wheels, nt05's, aac side-markers, more comingl ...
Old 10-29-2012, 08:40 PM   #9
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
Old 10-29-2012, 09:37 PM   #10
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
Only untill you let go of the pedal, the ecu will kill timing and fuel to prevent an unentended acceleration event.
2010 RS2SS, XS POWER HEADERS AND FULL EXHAUST, ROTOFAB COLD AIR AND ENGINE COVERS, MSD PLUG WIRES. PFADT DROP SPRINGS, SPORT SWAY BARS, TRAILING ARMS, TOE LINKS. HURST SHIFTER, BILLET PEDALS.
BLACKOUT TAIL PANEL, TINTED TAIL LIGHTS, MAIL SLOT BLACKOUT, WHITE BOWTIES
greenmachinedriver is offline   Reply With Quote
catchcan, clean, manifold, oil
