Old 10-10-2012, 08:25 PM   #1
Nate GM
Rand Paul 2016
Nate GM's Avatar
Drives: Corvette Stingray Z51 2LT
Turbocharged V6 Horsepower?
I have a 2012 Camaro RS with a V6 and was wondering about how much horsepower I would have with an STS Turbocharger? I currently have a stock 323 horsepower engine with flowmaster exhaust. Also, what else could I do to it as well (CAI, Suspension etc.)? It said on their website to expect bolt on gains up to 150 hp but that I could also be capable of 620 hp. The 620 horsepower comment is what threw me off so any info on this would really help. Thanks so much!
Nate GM is offline   Reply With Quote
Old 10-10-2012, 08:27 PM   #2
Nate GM
Rand Paul 2016
Nate GM's Avatar
Also, no comments about trading it in for a V8 or anything like that. Thanks
Old 10-10-2012, 08:28 PM   #3
Taintedveins
Shark attack!
Taintedveins's Avatar
Drives: 2011 Camaro LS
No way will you get 150 hp out of bolt ons... Ricer math doesn't work. If you really want to know the results look up member GretchensGotGrowl (correct if name is wrong) That v6 is currently the most powerful turbo v6 camaro.
Taintedveins is offline   Reply With Quote
Old 10-10-2012, 08:28 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://www.camaro5.com/forums/showthread.php?t=115679
Member (manufacturer)--HP/TQ--1/8--1/4
Camaro-21 (STS)--415HP/408TQ at 10psi
cjt037 (STS)--436HP/405TQ at 8psi
Old 10-10-2012, 10:43 PM   #5
TurboSS_
SS boiii
TurboSS_'s Avatar
Drives: '09 Cobalt SS
CAPABLE of 620hp and just buying a turbo kit don't mean much. you'd have to be running 23-25 psi on a massive turbo to get 620hp out of that v6. meaning you'd want forged internals, crank, maybe new valve springs. you'd need all supporting mods and i can garuntee that on this platform, it would not be easy to obtain that number.
on the other hand, anything is possible if you have the money. so, hell, go for it.
'09 Cobalt SS Turbo .....HP Tuned @ 21psi
ZZP Catless Downpipe, Hahn CAI
TurboXS RFL Cat-Back, TurboXS Charge Pipes, TurboXS Intercooler
TurboSS_ is offline   Reply With Quote
Old 10-11-2012, 12:50 AM   #6
11 Camaro IBM
Drives: Camaro IBM
150 hp is not ricer math with a turbo kit rx's kit gets you around 400 at the wheels that's much over 400 at the crank so it's not impossible for a base line kit to get you that much but you will need supporting mods and a tune. I would look into either IPF or RX for kits I haven't heard very much from sts and 600 is a little far fetched
11 Camaro IBM is offline   Reply With Quote
Old 10-11-2012, 06:16 AM   #7
SpkCamaro12
SpkCamaro12's Avatar
Drives: 2012 IOM 2LT RS - Traded In
Ya 600+ plus HP is pushing it, Ive talked to Tracy a little bit and their kit gets between like 4-470, as Tracy said that is SS Killer already, but getting 600+ HP out of the V6 isn't going to happen, if you want 600+ HP get a SS TT/SC or anything else higher.
TRADED IN - 2012 2LT RS - VMAX Throttle Body - MRT V1 - CAI - Trifecta Tune - Matching Interior Lightning (Footwells and Dome) - Sequential Taillights - Blacked out Front n Back Bowties - 228VX Train Horn
Traded for 2011 Corvette
http://img62.imageshack.us/img62/7428/sig2gx.jpg
SpkCamaro12 is offline   Reply With Quote
Old 10-11-2012, 07:05 AM   #8
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
Gain from boost varies depending on whether or not you can pump enough fuel in, whether you have enough octane to avoid detonation, the efficiency of the system, intercooler or not, etc....
A 150 hp gain would be pretty significant on its own, but probably doable. Getting to 620hp without blowing stuff all to hell would require re-engineering and rebuilding most of the car (fuel system, cooling system, engine, transmission, clutch, rear end, etc...).
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 10-11-2012, 07:21 AM   #9
sycraft
COTW 5/06/2013
sycraft's Avatar
The 2012 has a better fuel setup than the 10-11. delivers more fuel when needed. I am north of 400 hp on my 2012. The IPF kit is great and makes great hp out of the box.
Old 10-11-2012, 08:07 AM   #10
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Did they 620 HP at the wheels or the crank? I have an auto and we had it up to about 500 RWHP @ 9 psi before backing it down to 450 RWHP at 8 psi. Given about 20% drivetrain loss 500 RWHP would be about 620 HP at the crank. Now, I have a few more goodies besides turbos and much better turbos than what come with the STS kit. So, yeah you could probably make 620 HP at the crank, but you won't do it with their kit alone.
Do you really want that much power? Adding 150 HP at the crank is almost 50% more than you have now.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-11-2012, 12:15 PM   #11
KMPrenger
KMPrenger's Avatar
Adding 150 HP to crank is about about the norm (a little higher than the norm) for the SC kits. 370+ rwhp on an auto, and 400+ on a manual car is where you'd be at when adding 150 to crank HP and we have seen those numbers.
Over 600 even at crank is a bit stretched at this point. It appears that Gretchen got near to that, but I feel like once you go that far the engine internals need to reworked/forged (which I think he has done or is working towards doing) + your going to need lots of supporting mods.
Very few of these cars has put it down where it counts...on the strip. There is some disconnect there that we need to figure out. Suspension/tires/launch/driver/ECM cutting power.......it hasn't all added up just yet.
Old 10-11-2012, 01:10 PM   #12
GretchenGotGrowl
Exactly, and the engine should handle that easily. The crank is sinster forged as are the rods. However, if you have a M6 you may have some tranny issues. If you have an A6 then the differential my give you some problems. Most importantly, going much beyond this and you should be more worried about things that let you put that power to the ground. As the saying goes, if you're spinning you aren't winning.
Just be patient for a bit longer. Besides, you may have to be a bit nuts to try and double the HP on a stock block. When I break that I think we'll really know what one can take. I just don't see any aftermarket race blocks being built for the LLT or LFX.
Damn tune is what's killing me. Think the in-tank fuel pump also can't keep up above about 450 RWHP for very long. Working on that issue now, too.
Old 10-11-2012, 03:41 PM   #13
SteveRS
SteveRS's Avatar
Drives: 2010 SIM Cobalt SS
Send a message via AIM to SteveRS
LOL i miss my LNF SS.... Destroyed the V6 camaros... and V8 R/T challengers lol
2011 Imperial Blue 1.5SS
2010 Silver Ice Cobalt SS
SteveRS is offline   Reply With Quote
Old 10-11-2012, 04:07 PM   #14
GretchenGotGrowl
Yeah, the LNF was an awesome motor. A lot of that technology made it into the LLT and LFX. Now we will see it move up to the V8s. Very cool for all.
