![]() Drives: Buick Enclave/Corvette/2010 Camaro Join Date: Aug 2008
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM!
I just got off the phone with a Comp Cams tech who did some work in the R&D area and who keeps close tabs on the development of their new line of CAMs for the L99 motor.
Competition CAMS already has a line of CAMs for the VVT motors without AFM (DOD) or for motors that have the DOD scraped . They use a cam phaser limiter to reduce the max range of adjustment from 50- 60 down to 20 degrees. This allows the additional clearance for more lift (I think 30-40 was a conservative number mentioned, but I could be wrong) For the L99 VVT application and retaining the AFM, preliminary numbers suggest .500 is the max lift that the stock AFM lifters can accommodate (or pretty much stock… does anyone know the L99 and LS3 cam specs) Can’t do high ratio rockers without also adding stress to the stock lifters, nor can you use stiffer springs (though I don’t see any need to with a low lift cam) Most of the gains will be from increased duration. Comp Cams will come out with 2 or 3 VVT grinds supporting AFM. (They have their lead developer working hard at finalizing the profiles ) I was told that the tuning needs to be reprogrammed so the advance mechanism does not try and force the cam to advance beyond the desired range and have to compete against the phaser limiter) He told me to call back next Friday and he should have more details, and likely availability of these new grinds. That’s the extent of my notes. Note: Being somewhat old school, I did not know you could swap the cam without removing the lifters or intake, Now I’m really happy. So, for me I’m waiting to see what sort of gains are possible without removing the AFM (which the service dept will likely spot more easily than a cam swap) I’m watching Comp Cams and New Era to see what is possible with the AFM intact. Things are getting interesting .....
***56K miles and still going strong*** 2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM Gary Custom Z vented fenders. Vararam ver 2 |
AwesomeBillDawesonville
Drives: CGM 2SS/RS =) Join Date: May 2009
This is great news for L99 owners!
.500 lift is enough With a longer duration, will ya need to get new injector to handle the fuel demand?
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM |
![]() Drives: 6 camaros Join Date: Feb 2009
the lifters are in retainers, so once the rocker arms are off, the cam is rotated and the lifters stay up..
as for injectors, no need, the stockers should handle to close to 550 hp I bet.. or 475rwhp..
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427 2002 SSLE Convertible 1968 383 Camaro 1968 327 Camaro Convertible 1967 RS 327 1967 Pro-Tour LS3 in progress |
![]() Drives: C6 Zed-oh-six Join Date: May 2009
cool! cant wait to see some numbers!
Drives: 98 Camaro Race Car 3.96 @ 202 MPH Join Date: Mar 2009
The lifters are in lifter trays. You have to spin the stock cam shaft at least 360* to pump the lifters up. Once that is done you can pull out your old cam shaft and install the new one. You just have to be VERY carefull a lifter does not fall. If it does, ALOT more labor is involved that you do not want to hear about.
FIRST C7 Corvette in the 7's & 9's 2019 ZR1 LT5*9.00*@ 157 Current C7 World Record Holder 7.55*@ 184*MPH Quickest and Fastest GEN5 LT Powered Vehicle LMR1200HP Supercharged C7 8.84 @ 160** LMR1200HP Twin Turbo C7 9.35@155mph-2014 2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010 9.47 ZR1 Corvette-2009 FIRST 2010 CAMARO in the 9's-2010 713-466-9900 Latemodelracecraft.com |
#6 | |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#7 |
![]() Drives: 2010 Camaro 2SS VIN#11184 Join Date: May 2009
Is this legal to do in Virginia? xD!
#8 | |
there are the magnet tricks and others to help make sure the lifters stay up.. I built one of the first Darton sleeved 427 LS motors back lots of yrs ago, so I am aware of whats up on these motors.. no worries there
#9 |
NOICE!!! ™
Good news for the L99 crowd
#10 |
Master of Medicine
Drives: 4th Gen Join Date: Oct 2008
Mast motorsports has been doing VVT cams for over 2 years now...they are way ahead of the curve...you should check them out.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
#11 | |
#12 | |
If you were 2000 miles closer you might see me walk through your door. Anyone doing this work in the VA/MD area?
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
I would say give Comp a call, or shop their website when they are available...and find a good shop for the install...I could shwo you some good folks in the Phili or NYC area for the work.
#14 | |
I’m be looking for a MD/No Va shop that can do a baseline dyno pull, then I’ll add exhaust, CAI, under drive pulley (perhaps a overdrive alternator pulley as I want to add a small sub/amp). Then bring it back for the cam install , tune with a final dyno pull. (with the tune I’m also looking to tweak the AFM as well as do something about the shift lag, and other aspects on the automatic trans. perhaps a easy way to return the tune to stock if I ever have to return to the dealer for powertrain issues) Once I get use to this combination (and see that the Power train is sound) , I may consider the Maggie (and say then goodbye to the engine warrantee)
| For the L99 | Hesh | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 38 | 01-11-2009 11:44 AM |
