Old 10-11-2012, 02:17 PM   #1
DieselEffect
DieselEffect's Avatar
Drives: Red Hot 2016 Chevrolet Camaro 2SS
Exclamation Rear tires not holding air?
I only have about 20k on these Pirelli P-Zero (second set) and all of the sudden one day the rear tires decided to start leaking about 20psi per day. I took them to Sears and they told me that my tires needed replaced because they are too worn down (oops). However, I put twice as many miles on the tires I had from the factory and they NEVER did this. Anyone else have this problem? Also, when I do replace the tires does anyone have a recommendation on what I should get other than the P-Zeros?
DieselEffect is offline   Reply With Quote
Old 10-11-2012, 02:20 PM   #2
RSloth
[COTW- Never!]
Drives: Slothy; Sloth-like
Well do you race? or do anything that would require excellent grip?
I have 480 tread wear on my generals and they will probably last me a year
as for racing, next year I'm getting a set of Nitto's NTO5s or INVOs are good..
RSloth is offline   Reply With Quote
Old 10-11-2012, 02:20 PM   #3
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
If you are losing 20lbs per day you either have holes in your tires. Objects in them causing a leak. Damaged or faulty stems or they are leaking from the bead. At that rate of loss you should be able to dump water all over the tire and find a leak.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 10-11-2012, 02:22 PM   #4
Xorak
Xorak's Avatar
Drives: ...
did you let the dealer drive it?
Xorak is offline   Reply With Quote
Old 10-11-2012, 02:29 PM   #5
DieselEffect
HA!! No I didn't. But that made me laugh.
Old 10-11-2012, 02:29 PM   #6
DieselEffect
No I don't race or anything. My car is completely stock. haha.
Old 10-11-2012, 02:33 PM   #7
Dtrimpi87
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS
Lmao I have a feeling this going to be a running joke from here on out.
Dtrimpi87 is offline   Reply With Quote
Old 10-11-2012, 02:53 PM   #8
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
I went with the B F Goodrich G-Force Comp 2's. A much, much better tire than the stock ones. Better handling, longer wear rating, don't follow ruts and they were cheaper.
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 10-11-2012, 10:13 PM   #9
oldfriend
Drives: Fiat 500 E
Call Jenny Craig and see what's up with that , 20 lb a day ? !
air, donuts, leaking, pirelli, tires
