06-03-2009, 08:44 AM | #1 |
STANG KILLER
Drives: 1969 Camaro SS Join Date: Jul 2008
DSE Performance Handling Kit
Just a FYI Detroit Speed & Engineering is make a handing kit for 2010 camaro, Parting with Hendrick Performance Group
http://www.detroitspeed.com/projectp...amaro-main.htm Check them out! They make the BEST Suspension system for first and second gen camaros... There new system is going to be one of the best on the market for the 2010!
Automotive press asked Chevrolet product managers
"What is a Camaro?", "a small, vicious animal that eats Mustangs". (wikipedia camaro) Last edited by BAMA 69; 06-04-2009 at 07:43 AM. |
06-03-2009, 10:52 AM | #2 |
Interesting. I wonder if some of these parts will be lighter than the stock parts?
06-04-2009, 07:15 AM | #3 |
STANG KILLER
That I don't know,
But the owners of DSE both were GM suspension Engineers before they started DSE, just a little info about the company
"What is a Camaro?", "a small, vicious animal that eats Mustangs". (wikipedia camaro) |
06-04-2009, 07:40 AM | #4 |
STANG KILLER
Just got a email form DSE
Detroit Speed Brings You the DSE Performance Handling Kit for Your 2010 Camaro Detroit Speed is known for their performance and ride quality of early Camaros. Now you too can have Detroit Speed suspension technology underneath your new 2010 Camaro. Rick Hendrick, owner of the Hendrick Performance Group and Camaro Enthusiast, has joined forces with Detroit Speed to engineer a Performance Handling Kit for the 2010 Camaro. This kit will be available through Detroit Speed and select Hendrick Automotive Dealerships as an upgrade for the 2010 Camaro. The Performance Handling Kit includes Front and Rear Drop Springs and a Front and Rear Sway Bar. The Drop Springs lower the ride height to give your car a more aggressive stance. The increased progressive spring rates provide improved performance handling while retaining excellent ride quality. They are a direct replacement to the factory 2010 Camaro springs. The DSE Drop Springs retain the factory isolators. The Front and Rear Sway Bars have a larger diameter than the OEM with an increased rate for improved performance handling. The Front Sway Bar also includes high-performance fully adjustable aluminum end links. These end links are a great way to upgrade from the small factory end links that are in your stock Camaro. The Sway Bars are powdercoated gloss black. The Sway Bar bushings and custom heavy duty end links are also black for a clean uniform finish.
Similar Threads | ||||
V6 Camaro Performance Upgrades | rtcat600man | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 387 | 09-19-2019 06:53 PM |
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit | Jason 98 TA | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 03-17-2012 10:22 AM |
DSE coming out w/ a performance handling package | YancyJohns | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 05-27-2009 07:57 PM |
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit | Jason 98 TA | V8 Bolt-Ons & Tunes | 1 | 05-20-2009 10:40 AM |
Video!! Insight into Camaro performance and Handling | chewy4ce | 5th Gen Camaro SS LS LT General Discussions | 6 | 01-18-2009 10:42 PM |
