Old 10-18-2012, 07:26 PM   #1
belliott
belliott
Drives: 2011 Camaro SS Convertible
Heated Seats with Remote Start
I cannot finds a thread on this, but i'm wondering if there is a way to get the heated seats kicked on when I use the remote start?
Its getting cold around here and this would be really nice.
belliott is offline   Reply With Quote
Old 10-18-2012, 07:29 PM   #2
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 2LT to 2SS Manual Conversion
If it's anything like the wife's Equinox, the HVAC system has to be set to automatic before the engine is shut off.
mr_honez is offline   Reply With Quote
Old 10-18-2012, 07:37 PM   #3
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
There is no automatic setting lol.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 10-18-2012, 07:40 PM   #4
kostnkost
Roof expert detail noob
kostnkost's Avatar
Drives: 2013 BRM 2LT RS
Mine came on a week ago when it got cold here. I know for a fact I did not turn them on, so it must be a setting somewhere. Either that or they turn on automatically when the car is a certain temperature inside.
kostnkost is offline   Reply With Quote
Old 10-18-2012, 07:43 PM   #5
RSloth
[COTW- Never!]
Drives: Slothy; Sloth-like
Its on your radio settings
go to climate control or something and thats the only option hah.
RSloth is offline   Reply With Quote
Old 10-18-2012, 07:57 PM   #6
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Now now don't be so narrow minded... you can get one of those heated seats from walmart, plug it in your lighter and leave it on, when you remote start the lighter becomes active and then heats up your seat. You have to think outside of the box.
=Stephens= is offline   Reply With Quote
Old 10-18-2012, 08:01 PM   #7
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
This, my seats have been coming on for the past couple of weeks.
SPARTAN sui is offline   Reply With Quote
Old 10-18-2012, 08:08 PM   #8
Crisco
Crisco's Avatar
Drives: Black 2LT/RS
this may sound corny but there is an app for that. if you have an onstar subscription and a smart phone you can download the onstar app and remote start your car from your phone it also checks tire pressure fuel mileage and everything like that its a pretty good app IMO i hope this helps
Crisco is offline   Reply With Quote
Old 10-18-2012, 08:50 PM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Does no one read the manual anymore? It can be done but be warned the heater coil will not be in direct contact with the seat without someone sitting in it and as such it will take awhile for the seat to warm up (about 10 mins). Also this option will only turn the seats on when the temperature falls below a certain point (I believe 40 degrees but not sure). It's just now starting to get cold here and some mornings they will come on and some they won't but they always comes on when the "Caution Ice Possible" warning comes on which happens at 37 degrees.
Entering the Personalization
Menus
1. Press the CONFIG button to
access the Configuration
Settings menu.
2. Turn the MENU/SELECT knob to
highlight Vehicle Settings.
3. Press the center of the
MENU/SELECT knob to select
the Vehicle Settings menu.
The following list of menu items will
be available:
. Climate and Air Quality
. Comfort and Convenience
. Collision/Detection Systems
. Language
. Lighting
. Power Door Locks
. Remote Lock/Unlock
. Return to Factory Settings
highlight the menu. Press the knob
to select it. Each of the menus is
detailed in the following information.
Select the Climate and Air Quality
menu and the following will be
displayed:
. Remote Start Heated Seats
When on, this feature will turn the
heated seats on when using remote
start.
Press the MENU/SELECT knob
when Remote Start Heated Seats is
highlighted. Turn the knob to select
On or Off. Press the knob to confirm
and go back to the last menu
Old 10-18-2012, 09:56 PM   #10
mr_honez
Wifey Lover
mr_honez's Avatar
Shows how much I drive her Nox lol. My current car is one level above having a pull starter in the dashboard...
Old 10-18-2012, 10:00 PM   #11
Cam2011
Drives: 2011 Camaro 2SS/RS
Cam2011 is offline   Reply With Quote
