Old 10-20-2012, 06:08 PM   #1
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
Drives: 2010 2SS/RS CGM
best amp to swap out the BA with??
I am looking to take out this garbage BA amp. What kind of amp do I need as far as watts and rms??I really dont have any idea aboutamps and what not...I do know i need a FARK harness tho
JBA 1 7/8 LT`s, High flow mids, and Cat back,Airaid intake, JRE Tune, & alot of flat black....
CyberBri is offline   Reply With Quote
Old 10-20-2012, 06:16 PM   #2
vtxretro02
vtxretro02's Avatar
Drives: 2012 Camaro 2ss Heritage Grill/GFX
my recommendation jl audio xd 400/4 same size as oem
vtxretro02 is offline   Reply With Quote
Old 10-20-2012, 07:16 PM   #3
Legend96
Drives: 2013 ZL1 Victory Red
That's the one I used as well! Worked out nicely!!!
Legend96 is offline   Reply With Quote
Old 10-20-2012, 08:19 PM   #4
Steve@Subthump
Drives: 2011 2SS IOM Vert
Me too. Very first amp permanently installed using our fark kit and amp mount
Steve@Subthump is offline   Reply With Quote
Old 10-20-2012, 08:27 PM   #5
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I have the JL440/4 amp installed using the ******** FARK harness and mounting board. Sound good.
Caddy
Caddyroger is offline   Reply With Quote
Old 10-21-2012, 05:28 AM   #6
2010SSRSM6
2010SSRSM6's Avatar
Are you wanting to keep your trunk space or are you open to an amp that will fit outside the factory location?
I am running an Arc Audio 900/6 with the FARK kit.
Old 10-21-2012, 09:02 AM   #7
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
What trunk space lol. I thought u could use any other than a 4 channel??does ur make more power or louder music??
Old 10-21-2012, 08:33 PM   #8
whitehorse
whitehorse's Avatar
Drives: 2010 IBM Camaro 2SS
When replacing with the JL audio amp do you still have all your chimes, back-up sensors, etc?
whitehorse is offline   Reply With Quote
Old 10-21-2012, 09:32 PM   #9
monstertodd
monstertodd's Avatar
He's just asking you if you are open to the idea of using a larger more powerful amp so you can run more speakers (sub).
A physically larger amp will not fit in the location that the factory amp is mounted. The JL amp above will fit in the same space as the factory BA amp. He wants to know if you are open to mounting a physically larger amp in another part of the trunk.
Old 10-22-2012, 05:51 AM   #10
DangerZL1
Drives: 2023 Black ZL1 Auto
If you use the ******** FARK kit I understand that all the above will function. I've been leaning towards the JL audio XD700/5 amp to make a sub easier to install later. I believe it will fit in the stock space as shown in the above pic.
DangerZL1 is offline   Reply With Quote
Old 10-22-2012, 12:33 PM   #11
CyberBri
BRUCE WAYNES DD
CyberBri's Avatar
I dont really care how big the amp is. I meant to say i thaught you could not use any amp besides a 4 channel one?? Is it possible to run a 5 or 6 channela mp??
Old 10-22-2012, 01:43 PM   #12
cabbe
Drives: 2014 2ss 1le
Hey Steve!
I already have one of your add an amp harnesses, that I am using to run a separate amp to my aftermarket subwoofer. Now I'm thinking that I would like to add one of these jl xd 400/4 amps for my regular speakers. What other harness would I need to buy from you to get this jl amp to work with my other sub amp?
cabbe is offline   Reply With Quote
Old 10-22-2012, 03:09 PM   #13
Steve@Subthump
Originally Posted by cabbe View Post
Hey Steve!
item 5G-fark less x3
http://********.com/Chevrolet-GMC-Su...ement-Kit.html
Old 10-22-2012, 04:13 PM   #14
cabbe
Awesome!
Thanks, now I just got to find a amp.
