Old 10-22-2012, 02:03 PM   #1
Fluxil
Drives: Black 2012 Camaro
2012 Camaro v6 Automatic (Question)
Is there a limit on how fast it will go?
Im getting one really soon and I wanted to know if it does, I don't like limits on cars I own because If im paying for it then I want all that it can do
No stupid remarks like you'll never go faster than XX speed.
Just tell me if it has a limit on it, and if it does how to remove it.
Fluxil is offline   Reply With Quote
Old 10-22-2012, 02:04 PM   #2
mattsfirstSS
mattsfirstSS's Avatar
Drives: 2012 Camaro 1SS/RS L99
Yes, Tune...
mattsfirstSS is offline   Reply With Quote
Old 10-22-2012, 02:09 PM   #3
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
118mph with factory 18" rims, 146mph with 19"+ option.
You get higher speed rated tires with the larger rim options.
I think 146mph is top end of the v6 (stock), but I could be wrong. Maybe LFX is different from the LLT (2010-2011)
SPARTAN sui is offline   Reply With Quote
Old 10-22-2012, 02:16 PM   #4
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
Get the RS package and you'll be limited to 145-146. That's plenty fast enough!
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 10-22-2012, 02:17 PM   #5
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Actually the RS package is limited to 155.
18" heritage wheels and steelies are 118mph.
A tune will take the governor out but I don't know what top end on the V6 would be. I'd assume high 160's. I'm sure someone on here knows-- though I doubt they'll speak up and risk getting flamed
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 10-22-2012, 02:24 PM   #6
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
You can go as fast as your wallet lets you. Void warranty, remove governor, get the engine tuned. Drop a turbo, cam, crank, exhaust, intake.
But for stock it is what is stated above. But really who needs to go over 100 mph anyways? Most states that is reckless driving which is 6 points off your license and jail time.
=Stephens= is offline   Reply With Quote
Old 10-22-2012, 02:29 PM   #7
jd10013
Drives: 2012 camaro
as someone else mentioned, you'll void your warranty if you remove the speed limiter. definitely something to consider. before you do it.
your probably better off just getting the RS package as that will get you up to about 155. I don't know the exact number, but a V6 in a car the size and weight of a camaro will probably have a top speed of 165 anyways. I think that extra 10, or maybe even 15 MPH isn't worth voiding your 5 yr 100k mile powertrain warranty.
jd10013 is offline   Reply With Quote
Old 10-22-2012, 02:38 PM   #8
crateish
crateish's Avatar
Drives: 45th Anniversary 2LT/RS Coupe
I can say unequivocally that I have been able to get my 2LT up to every speed I have ever needed.
crateish is offline   Reply With Quote
Old 10-22-2012, 02:48 PM   #9
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Well with the auto 2012s you get a few options. The 2ls is limited to 118 from the factory, the 1lt and 2lt without the RS package are limited to 145, and any car with the RS package is limited to 155. Out of the v6 cars, the 2ls is capable of higher speeds in the top end due to its 2:91 gear ratio. To achieve those higher speeds however, a waranty voiding tune would be required.
soloknight6 is offline   Reply With Quote
Old 10-22-2012, 02:49 PM   #10
camaro-dreamer
camaro-dreamer's Avatar
Drives: 2013 Porsche 981S
There is always a limit to how fast any car can go. This limit is called drag. The LS is the only camaro which isn't close to reaching its drag limit. This limit is primarily due to the tire ratings as mentioned early by another user. You can always add more horespower. Remember the drag force increases with the velocity squared, so there are limiting returns!
camaro-dreamer is offline   Reply With Quote
Old 10-22-2012, 02:57 PM   #11
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Car and Driver got the bone stock V6 with auto to do 157 with the guv disabled... and that's MPH, not KPH!
Scalded Dog is offline   Reply With Quote
Old 10-22-2012, 03:23 PM   #12
crateish
crateish's Avatar
155! Good God!
Now that I know that, my wife and I can get to and from our favorite bar much faster.
Thanks!
Old 10-22-2012, 03:41 PM   #13
mattsfirstSS
Originally Posted by crateish View Post
155! Good God!
Thanks!
Getting "from" at 155 will be the problem...hard to drive 155 with one hand over one eye.
Old 10-22-2012, 03:50 PM   #14
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Glad your in Kentucky, unless your planning on going to the track.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
