crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
Deatschwerk or Racetronix Injectors
looking at injectors for when i decide to go E85...already doing the fuel pump upgrade and going to do an injector upgrade at the same time. don't want them running at 80% the whole time.
http://www.texas-speed.com/p-2352-ra...FY-6zAodpSYAtw http://weaponspeed.com/fuel-upgrade/...s-65lb-hr.html additionally, is there "too big of an injector"? when running on regular pump gas and being NA...will these be too big? thanks
![]() ![]() ![]() Drives: 2010 M6 2SS Join Date: Mar 2011
Injector Dynamics
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
yes, i've heard nothing but great things about the ID 850's, but i'd like to hear about these instead.
thanks for the input though.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
I'd image if you went too big on injectors it could make tuning down low difficult.
She is only memory now. |
thanks Indeed.
yeah, i was wondering how much it would effect idle and cruising. not going to put out crazy amounts of power...maybe 50's would be sufficient?
#6 |
Racetronix are good too. I know Paul at PRJ Performance likes their stuff, as I recall. But that was W-Body builds.
#7 |
E85 needs more fuel even at idle, so bigger won't be as hard to tune as they could be with gasoline...also with these newer pcm's and newer injector technology, it's not so bad at all.
Whatever injectors you choose, make sure that the correct calibration data for them is available...it saves hours of headache tuning.
#8 |
Drives: 2010 SS/RS 2009 CG Z06 Join Date: Nov 2009
Injector Dynamics.
#9 |
He knows about those, but was only inquiring about the Ractronics and Deatschwerks.
#10 |
He probably knows about whataburger and braums, but still eats at McDonalds too then? You can lead a horse to water, but you cant make him drink
![]() As far as too big of an injector, yes. Absolutely, but only on automatic cars. The Autos use the MAF scale to determine load. we have a 62lb/hr limitation in the PCM, which forces us to scale the MAF table back, to reduce fuel. This inturn, reduces the "load" that the computer sees, and you run a VERY high risk of burning up or hurting the trans. Manual trans cars dont care, you can run any size, and scale the MAF anyway you want. |
#11 | |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
#12 | |
but on a personal note, i despise mcdonalds ![]() there has been all kinds of talk regarding Injector Dynamics and how "awesome" they are. but haven't seen much of anything regarding these other two. so this is why i am asking about the other options out there. i don't want to buy something just because thats what everybody says to buy. unless of course there is a reason(s) as to why. what are the experiences that people have come across using these companies. as a tuner...have you actually tried to tune these? if so, what were some of the issues you ran into? its one thing to tune when your customers buy what you tell them to (Injector Dymanics) because either you are familiar with it or simply because its easier. but having some comparative data as to WHY you prefer one over the other, which equates to experience working with them is what im asking for. IndeedSS1...
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
the 5th gen camaro e38 ecm's dont have the 62lb/hr limit they go all the way up to 127lb/hr injectors before any scaling is needed
#14 |
When you put a new injector in your car, the flow rates, low pulsewidth modulation, linearity all change.
If you just change the one big table in your computer, for injector flow rate, you are missing 5 other tables that MUST change with a new injector. When you buy a FAST, DW, Or seiments, or what ever injector, they do not provide the necessary offset, min PWs, etc etc data that WE NEED as calibrators. Injector dynamics does. They give you the data you need, to make the car run correctly. There is a reason that there has been a mass movement to Injector Dynamics. Yes, its the cool thing to have, and there is a reason, its the cool thing to have. If your tuner doesnt understand the necessary tables that must be modified with new injectors, then he doesnt need to be tuning. Hes "tooning" not "tuning". If you bring me a car with an aftermarket set of injectors, and you cannot provide me the data I need to do my job, I wont tune it. Its as simple as that. Louis |
