Old 10-23-2012, 11:39 AM   #1
dookie454
Drives: 2010 Camaro 2SS LS3
Whipple Installed, now seeing artificially low IAT's
I just installed a Whipple complete kit on my 2010 LS3 Camaro... now I see something interesting with the "low" intake air temps: My running/driving logged IAT's run about 15F above ambient.. but now I noticed this:
Over the last few weeks the car's been sitting at various temps for ~20+ hours inside my garage... and the garage temp is within 2 degrees of the coolant temp... and the ambient temp on the radio matches the coolant temp also within a degree or two.. and I see this right before I start the car:
Coolant Temp/Ambient Temp-----------IAT Temp
55f-----------------------------------39f (-16f) (41f = 4536 resistance in the cal info)
59f-----------------------------------43f (-16f)
72f-----------------------------------57f (-15f) (59f = 2976 resistance in the cal info)
Any idea's? I haven't taken the sensor out to verify with a thermocouple since it's hard to get too.. but i will at some point.
Anybody else see this or is something wrong with my setup?
dookie454 is offline   Reply With Quote
Old 10-23-2012, 09:56 PM   #2
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
I added an UltraGauge a few weeks ago and have noticed a similar reading variation :( , starts out 10-15 below air temp.
Just made a quick trip out to the car to verify that its like that before startig.
The car has been sitting for 24 hours and the temp of on the radio shows 81 ... the Intake showing 66.
Not sure whats going on.
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
Indyblue98 is offline   Reply With Quote
Old 10-23-2012, 11:29 PM   #3
dookie454
Well, I know I didnt screw up my install since I did it myself, I triple checked the whipple tune's IAT cal, and it's the same for the stock IAT sensor (Whipple did not change the IAT cal).
So, it's starting to look like the Whipple IAT sensor simply reads ~15F below actual temp. How's that for marketing!
It still runs good, doesnt knock with the reported IAT's near 85F (which might actually be 100F), so Im not too concerned.. but still is an issue since they are shipping kits this way and every single person I read on the Internet with a whipple'd Camaro LS3 says (think) they are running IAT's that are only 15F over ambient.
Old 10-24-2012, 10:35 AM   #4
wkdivr
Drives: 2004 GMC
Are they still shipping kits using the IAT sensor in the intake tube, or is it in the lower intake tub? It should be in the lower intake tub.
wkdivr is offline   Reply With Quote
Old 10-24-2012, 11:18 AM   #5
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Maybe this is part of the reason everyone says they run so much cooler than the eforce !!
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 10-24-2012, 11:46 AM   #6
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
iat sensor in below the blower in the rear.
Whipped416 is offline   Reply With Quote
Old 10-24-2012, 12:11 PM   #7
dookie454
Yep I just got my Whipple, straight from Whipple, the sensor is on the pass side lower rear corner, though this has nothing to do with location and all to do with calibration.
If this is how it's always been, I find it hard to believe that it's gone unnoticed until now. And if it has.. then wow.
Old 10-24-2012, 12:59 PM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
Put this IAT Ohms to temp calibration in and let me know how it works
48 60 78 101 133 178 242 283 334 395 469 559 671 809 980 1195 1465 1806 2240 2795 3511 4441 5658 7263 9399 12261 16120 21371 28582 38583 52594 72437 100865
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-24-2012, 01:29 PM   #9
dookie454
I guess I cant do that, mine is this way:
302 284 266 248 230 212 194 185 176 167 158 149 140 131 122 113 104 95 86 77 68 59 50 41 32 23 14 5 -4 -13 -22 -31 -40
I could just add ~15 degrees to every point here and it would probably correct my cal... but... why is it like this? It shouldn't be. I'd like Whipple to explain.
Old 10-25-2012, 10:38 AM   #10
stanwilliams
3000 hp 648 ci beast
stanwilliams's Avatar
Drives: 86 Outlaw 10.5 Camaro, 2SS/RS LS3
He is talking about changing the labels not the values themselves. I just noticed that these are the same values as stock on the 2012 Silverado I am working on.
2SS/RS, LS3, 6M, IOM w/black hockey, IO interior, sunroof
mods: ******** setup. Whipple supercharger....Need suspension upgrades now... 4" stroker kit, ARH, cam on my wish list.
stanwilliams is offline   Reply With Quote
Old 12-31-2013, 12:24 AM   #11
RWTD
Drives: 2008 Z06
Hey brother, curious, is this still approx. the correct data to input? Working on a 2013 C6 427 Anniversary with Whipple and we, too, are seeing crazy low IATs. Thanks a ton for your help, as always!
P.s. Outside temps approx. 30F tonight and IC reservoir fluid was ICE COLD. Gotta love this IC system from Whipple. Bravo!
James
RWTD is offline   Reply With Quote
Old 12-31-2013, 09:04 AM   #12
JANNETTYRACING
Yes this goes in the Ynorm
