Old 10-23-2012, 11:14 PM   #1
Abrahams11SS
Drives: 2013 ZL1 V3RT
CEL p1074 and p1071. Wtf??
The car is at the dealership now and they are keeping it overnight and have no idea what's wrong as of the first day. Has anyone else been having this issue??
The car revs when I stop and burns way more gas then usual. 19mpg at best on the highway.
The only mods on the car are a catback exhaust and cai which have been on the car for 10k miles with no issues.
Abrahams11SS is offline   Reply With Quote
Old 10-24-2012, 01:09 PM   #2
Abrahams11SS
The dealer states that my airaid cold air kit are causing the car to run lean. That doesn't make any sense to me. Can someone explain or is it hogwash ??
Old 10-24-2012, 01:35 PM   #3
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
I think they're just looking for something to blame it on.
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 10-24-2012, 01:42 PM   #4
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
someone had an issue with traction control light coming on. Dealer said it was an over oiled cold air filter that screwed up the MAF sensor and made the car throw a lean code etc..
that was the first thing that came to mind after reading where you said dealer says your cold air unit is causing car to run lean...
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 10-24-2012, 03:04 PM   #5
Abrahams11SS
I was advised to call the intake manufacturer so I did. They have never had this issue before and are going to speak to their r&d department and get back to me and make sure it's not potentially a defect in their kit. I don't know what to think but the oil seems to be a potential cause. I will have to let them know and see if get helps. It just doesn't make sense for it to be the kit because it woul have thrown a code right away and not after a few thousand miles.
Thanks for the responses guys.
Old 10-24-2012, 03:45 PM   #6
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Dealerships are lazy and will try anything to blame you
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 10-24-2012, 07:06 PM   #7
caligrown562
Drives: 2012 1SS
what do you the mean the car revs when you stop? is it stick or auto?
caligrown562 is offline   Reply With Quote
Old 10-24-2012, 07:13 PM   #8
C5RocksC5
Banned
C5RocksC5's Avatar
Drives: 2010 Camaro 2SS/RS
an oil soaked filter will mess up the MAF. I have seen very oily (wet to touch) oiled filters come right out of the box. Most common problem is when people clean their oiled-air filter, they spray on too much oil...screws up the MAF 100% of the time.
C5RocksC5 is offline   Reply With Quote
Old 10-25-2012, 08:42 AM   #9
Abrahams11SS
It's a stick and when I push in the clutch to brake and ease to a stop the car revs at 1000rpm instead of the normal idle of like 500.
Old 10-25-2012, 11:31 AM   #10
caligrown562
Drives: 2012 1SS
mine will do the same thing. if I coast to a stop in neutral it sounds like I downshifted but not. right before I stop my rpms flare up but go right back down. is that kinda what your talking about?
Old 10-25-2012, 03:10 PM   #11
Abrahams11SS
Yes. And my mpg is gone to the crapper. 19 highway at best when I was gettin 23ish
Old 10-25-2012, 04:19 PM   #12
caligrown562
Drives: 2012 1SS
has the dealer figured it out yet? I haven't thrown any codes yet but I also have the stock intake. so if mines doing it too.. it's more then just your cai
Old 10-25-2012, 07:31 PM   #13
Abrahams11SS
No answer. I tried to talk to my service writer twice today and she was unavailable and didn't call me back when she said she would. I'm tryin to not get upset at this point and keep my cool. I'm fine with them needing the car longer to fix the issue. I just want to be kept in the loop.
Old 10-26-2012, 12:49 AM   #14
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
dude those are lean codes for both banks,more than likely related to you air intake or maf sensor,put o.e. air box on have codes cleared and see if they return
firestone_ss is offline   Reply With Quote
