![]() Drives: 2012 LT2 convertible Join Date: Oct 2012
are these stripes removable?
Hello gang,
I have a friend that has this Color scheme and would like to get black stripes instead. do these stick on or are they painted? how feasible is it to "switch" to the black ones? please advise |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2012
They are Vinyl, and can definitely be removed.
the glossy ones (orange) are vinyl as well?
can anyone walk me through the process of completely removing the orange and then applying the black? I can do it myself right? |
![]() Drives: Camaro SS & ZL1 Join Date: Sep 2011
Yes. This can be done on your own.
The factory stripe kit from the dealer is about 400 bucks. There are several DIY videos on YouTube which show you the entire process, including installation. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
I would spend the money to have it professionally done. It's not as easy as it looks.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
![]() Find a good vinyl shop in your area. You should look at getting the extended stripes as well. They look alot better and will set you even farther apart from your friend. I got a complete set of extend and customized stripes installed for $450 out the door. I also have my stripes go over the top of the rear spoiler as well. Looks much better IMO. You can acually see the stripes from behind.
Build Journal ![]() |
#7 |
Zach
Drives: 10 SIM 1LT, 66 F100 Join Date: Jul 2012
I'm sure its just peeling it away like a sticker... It's all the residue left over your gonna have fun trying to loose
2010 1LT
66 Ford F100 Camaro rep for Az ModRod Productions, havent liked us on Facebook? check it out! http://www.facebook.com/#!/ModRodProductions |
#8 |
My friend just got rid of his. No residue or sticky stuff left on the hood or deck lid. I think he used a hair dryer and heated them off. No hassel at all.
To my brother Scott, Thank you for your gift. I would give it all back just to have you here again.
Scott N. 08/05/64 09/28/2010 |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
I think the IOM stripe on white is an awesome retro look, but to each his own.
#10 | |
Like I mentioned above, maybe what you should do is remove the stock stripes and have some custom extended stripes added. Make them wider than stock and go all the way to the front of the car and over the rear spoiler. Keep the color....just change the style. Especially if you have the Orange interior.
#11 |
Turbine Maker
Drives: 2012 Camaro 2LT-RS "LFX"V6 Join Date: May 2012
Yes they are removable; I will have mine removed in December and have them painted on to get away from the wax issue since they are not wax friendly...
#12 |
![]() ![]() Drives: 2012 Camaro 1SS/RS L99 Join Date: Sep 2012
They are adams VRT friendly. I hear turtle wax black ice is good too. I just avoid waxing them and instead VRT them occasionally after having learned my lesson and left nasty wax streaks of course
(this was a joke, this was only a joke, If this had been an actual comment, the comment you just read would have been followed by
![]() ![]() or nothing at all) |
#13 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT RS Join Date: Sep 2012
Getting them off is not so tuff, but if you've never done it before you best have it done.
My2Sense
If you're not living on the edge, you're taking up too much space.
#14 |
The flat black one are not wax friendly but all the others colors are. They are vinyl. Just be carefully with the buffer near the edges, or just do the stripes by hand if you are not experienced with the buffer.
| Tags |
| orange stripes, stripes |
