Old 10-29-2012, 09:46 AM   #1
sonnydurden
sonnydurden's Avatar
Drives: ‘16 1SS & ‘19 1LT
SS at the Dealership - Marriage off to a Rocky Start..(update)
So I took my SS in this morning because scrubbing or rubbing like sound coming for the car when I turn at low speeds. Drives me nuts!! Car has only 2700 miles and this is bit early for an issue. And I inquired about the brakes squeaking all the time...Well, they told me that the sound I'm hearing is actually coming from the rear differential and they would have to take some things apart to figure out what exactly is going on (Great). I asked if this was a recall or anything and they said no. Then they told me that the brakes squeaking is normal because the Brembo's produce so much dust and its just the nature of the beast...hmmm, I use to own a 350Z that had Brembos...never had that issue....anyway, she will be sleeping away from home for about 2 days...hope its nothing serious :(
sonnydurden is offline   Reply With Quote
Old 10-29-2012, 09:58 AM   #2
Cam2011
Drives: 2011 Camaro 2SS/RS
I had an old chevy van where the rear diff would make a grinding noise, my friend (who was a GM tech) drained the fluid and replaced it with new fluid as well as some sort of lubricant additive and problem solved. As for the brakes the dust story sounds like BS to me, mine make a ton of dust, but no squeak.
Cam2011 is offline   Reply With Quote
Old 10-29-2012, 09:58 AM   #3
Cam2011
Old 10-29-2012, 10:04 AM   #4
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
The brembos do squeak on these cars. Mine doesnt do it every time but often.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 10-29-2012, 10:06 AM   #5
sonnydurden
Thanks man...but yeah, the brakes squeaking is BS...I just did a search on here and I'm not the only one...this seems to be an issue with the SS...but they are going to correct it...in less than a year I have bought 3 cars from this dealership...
Old 10-29-2012, 10:08 AM   #6
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
You're dealer is telling you the truth. The noise is from your rear diff, the fluid will have to be changed and the seals will most likely get replaced. It isn't a recall (those are safety related) but I believe it is a TSB (technical service bulletin) which is designed to address a concern if the customer has that specific concern.
And the brakes, yes they do squeak. Don't try to compare it to ANY other car you've owned, driven, seen, heard etc. There are those on here that have changed pads to eliminate the noise, and there are some (myself included) that it doesn't bother.
Keep us posted.
babytiger is offline   Reply With Quote
Old 10-29-2012, 10:10 AM   #7
sonnydurden
Its just so annoying...and I'm not complainer or is very meticulous about things..its takes alot for me to bring something in...I only get to enjoy this car on the weekends...so I want it to be right...
Old 10-29-2012, 10:11 AM   #8
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
As far as the brakes go, I installed Hawk Ceremic brake pads to get rid of the dust and squeaking. I can drive hundreds of miles and can't see any dust.
sscamaro is offline   Reply With Quote
Old 10-29-2012, 10:16 AM   #9
sonnydurden
Keep us posted.
Dealer telling the truth??...now there's a twist...lol...thanks for the input man. I will be happy to get her back safe and sound...as far as the brakes, I'm a bit disappointed to hear that alot people are experiencing this. Maybe I will try changing out the pads...thanks again
Old 10-29-2012, 10:17 AM   #10
sonnydurden
Appreciate that input...maybe I will give that try...thanks man!!
Old 10-29-2012, 10:42 AM   #11
oldschool69
oldschool69
Drives: 2012 2SS/RS
I have a 2012 SS and my breaks have never squeaked lots of dust thought, drives me crazy.
oldschool69 is offline   Reply With Quote
Old 10-29-2012, 10:51 AM   #12
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
The more often you wash the wheels and calipers out the less it will make noise. Don't have to really wash them. Just spray a hose right into the caliper, rotor and the rim. Works for me everytime for a few days.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 10-29-2012, 12:55 PM   #13
mavric01
Drives: 2011 2SS/RS Camaro RJT/BLK stripes
To get rid of the dust, and the squeak ......change to ceramic pads !!!!
Mav
mavric01 is offline   Reply With Quote
Old 10-29-2012, 01:10 PM   #14
alyssasdad
Go VOLS!!!!!
alyssasdad's Avatar
Drives: ZL1 #1344 VR, M6
Just a little tip. Make sure the dealer does a few figure 8s in your car after thay change out the diff fluid. If your service advisor does not know for sure if they did or not,find a empty parking lot and do it yourself. I changed my diff fluid out at 1500 miles and because of the many,many post on here saying to do this(figure 8s), I did. No noise.
1.GOD
2.Family
3.Camaro........& the TENNESSEE VOLS!!!
alyssasdad is offline   Reply With Quote
