Old 10-31-2012, 11:55 AM   #1
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
One piece radiator hose???
I've deleted my factory oil cooler and now need to delete the "T" style upper radiator hose.
I've seen others do this with a 1 piece upper radiator hose but I havent found the part #:(
I've done the search and seen some people mention they did it but no part #
Any help would be appreciated
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 10-31-2012, 12:17 PM   #2
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Don't you mean factory oil heater? When I installed our oil cooler on my car I just took my factory radiator hose to the parts store, and they let me wade through their hoses and matched one up. I don't know what car it is used for, but it fit well. I don't know the part number, but I think I have it somewhere, let me do a little research and see if I can find it.
- Jeremy
JDP Tech is offline   Reply With Quote
Old 10-31-2012, 12:34 PM   #3
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Factory "oil heater" is correct lol About 20 lbs worth of useless weight!
Taking to the parts store was a thought too and match it up! If you find the part # that would be awesome!
Thanks for the help
Old 10-31-2012, 03:33 PM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I have a one piece upper radiator hose available. Actually 2.
Old 10-31-2012, 04:32 PM   #5
JDP Tech
JDP Tech's Avatar
I found the one I used, Dayco C71766. It seems to fit well with a single trimming, and clears my ECS blower too. The quality of the Dayco hose is a little lesser than factory, so you can probably get the factory equivalent (which I will do soon). A quick Google search brings up this page which shows all the factory part numbers and cars its used on.
- Jeremy
Old 10-31-2012, 05:11 PM   #6
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Yeah you and everyone else
- Jeremy
Thanks Jeremy! I ordered the Gates 21508 which seems to be the equivalent and Gates is what my supplier carries. So we'll see tomorrow how that works out.
Thanks alot for your help
Old 10-31-2012, 09:13 PM   #7
PAUL SS
PAUL SS's Avatar
No, seriously, I do. Is that hard to believe?
Old 10-31-2012, 09:19 PM   #8
Slickcas
Drives: 12' 2SS/RS LS3 IBM
2012 SS have a one piece hose. Sorry do not know the GM part number
Slickcas is offline   Reply With Quote
Old 10-31-2012, 09:29 PM   #9
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
whats the heater used for? side question.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 11-01-2012, 11:14 AM   #10
JDP Tech
JDP Tech's Avatar
They also have a different radiator, so I'm not sure it would work, I've never really looked at it for that. The cooler line comes straight out of the radiator instead of the upper hose like the older ones.
The 2012 upper radiator hose part number appears to be 19259243 if you wanted to try it...
Officially it is an oil cooler, but it doesn't do that good of a job, and for most people it seems like the main use of it is to heat up the oil when it is cooler (warm oil is a good thing, you never want to run the engine hard with cold oil!)
- Jeremy
Old 11-01-2012, 03:06 PM   #11
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Just sayin all 2010 have "2" one -piece hoses to make one complete upper hose, just sounded like sarcasm. If you were'nt being sarcastic then i apologize. If you do have a true one-piece hose do you have a part #?
I did get the gates hose I mentioned above and is identical to the Dayco part # JDP referenced. It of course also needs a little trimming but that shouldnt be an issue.
Thanks all for the help.
Old 11-01-2012, 05:12 PM   #12
blackonblacksls
Drives: 2011 2ss/rs
I just bought one of those radiator splice kits. Plastic female to female piece that you just slide in placE of the factory tee
blackonblacksls is offline   Reply With Quote
Old 11-01-2012, 10:28 PM   #13
PAUL SS
PAUL SS's Avatar
I see what you were getting at, but the fact is I am in possesion of 2 upper radiator hoses that will eliminate the T fitting on 2 Camaros. A buddy at a chevy dealer was trying to order 2012 heater hoses for me but GM kept sending upper radiator hoses which have a similar part #, 1 digit is different. When they finally sent the correct hoses he gave me the two upper hoses. I noticed right away it was a solid one piece hose.
The GM part number is 19259243.
Old 11-02-2012, 02:56 PM   #14
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Will it fit on a 2010 or does it need trimming also?
hose, oil cooler, radiator hose, upper, upper hose
