Old 10-31-2012, 05:48 PM   #1
Bubble85
Drives: 2012 SS
Foot well
Any one got an electrical diagram for hooking uproot well lighting with a switch?
Bubble85 is offline   Reply With Quote
Old 10-31-2012, 05:51 PM   #2
Bubble85
Drives: 2012 SS
Foot well*
Old 11-01-2012, 07:47 AM   #3
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Did you search the DIY section? There are several threads showing how to install the foot well lights. While I do not have a diagram, I wired mine into a switch pretty easily. I added a fuse tap in the drivers side fuse box for constant power, and used a ground near the box as well. Once you have power it goes like this:
Power-switch-lights
Lights- ground
It you have a lighted switch you will need to ground the switch as well.
Deke736 is offline   Reply With Quote
Old 11-01-2012, 07:39 PM   #4
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
The foot well lights have a switch, what diagram do you need? I just installed the footwell lights, but I have to use the switch to turn them on.
Skylane765 is offline   Reply With Quote
Old 11-02-2012, 05:34 PM   #5
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
Power-switch-lights
Lights- ground
That pretty much sums it up.
awfarley is offline   Reply With Quote
Old 11-02-2012, 09:44 PM   #6
damneighborkid
damneighborkid's Avatar
Drives: Black 2012 Camaro 1SS/RS
I just T-tapped into the dome light wire (from the footwell block) That way I dont have to worry about a switch.
-Damneighborkid
I hereby certify that I am certifiable.
damneighborkid is offline   Reply With Quote
Old 11-03-2012, 11:05 AM   #7
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
I tapped the purple wire in the center guage cluster for constant power and sent my ground to a bolt that is in the center right under the radio. once you remove the plastic molding on either side of the center console you will see the ground bolt I used towards the front under the dash.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 11-03-2012, 02:23 PM   #8
Skylane765
Skylane765's Avatar
I have the install manual
