11-01-2012, 04:35 PM | #1 |
Drives: '13 Camaro 2LT/RS Join Date: Sep 2012
2013 Speedometer/Tach Needles do not move all the way up and down
When I start the car. :( Why?
My friend has a 2010 2LT/RS and whenever he starts his car, speed/tach needles go up and down. |
11-01-2012, 04:39 PM | #2 |
Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
the cycling gauges is part of the computers self test at startup to be sure everything is functioning correctly..
GM had been using this for many years, I recall my 2000 Silverado did this.. If yours is not doing it I suspect there might be a problem, I doubt GM would discontinue the feature all of a sudden, but I could be wrong. hopefully some other 2013 owners can chime in.. BTW my 2012 does it..
I'm only responsible for what I say, not for what you fail to understand.
11-01-2012, 04:47 PM | #3 |
I was thinking it is a feature that you can turn on/off, but couldnt find anything like that in a configuration menu or DIC.
Also, other gauges (oil press, transmission temp etc.) do go up and down. Weird shit. |
11-01-2012, 05:57 PM | #4 | |
sounds like there might be an issue. as I said the computer does that to self test the gauge cluster for errors.
11-01-2012, 05:58 PM | #5 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
See if another 2013 does this. My guess is that the full sweep was redundant, so they changed the cluster strategy.
Bye bye, Bumblebee!
11-01-2012, 06:06 PM | #6 |
Drives: 2013 SS/RS LS3 NPP/Hurst Join Date: Oct 2012
My "4 pack gauges" cycle but my speedo/tach do not.
11-01-2012, 06:35 PM | #7 |
11-01-2012, 06:40 PM | #8 |
Dang, why would they remove that. It looks so cool! :(
11-01-2012, 06:44 PM | #9 |
Drives: 2011 Camaro LS Join Date: Dec 2010
I thought it was incredibly annoying.
11-01-2012, 06:51 PM | #10 |
11-01-2012, 08:31 PM | #11 |
VroomVroom
Drives: 2017 50th 2SS Join Date: Apr 2012
Wow..you guys that like the gages to cycle - try changing from mph to kph while driving and watch what happens. LOL
2017 H50 2SS MX8 F55 NPP CF5 RN2
11-01-2012, 08:38 PM | #12 | |
Drives: 2012 AGM 2SS Join Date: Feb 2012
As for the guages cycling, I have always hated it. I wanna know what rpm my car is turning right when it starts, not 5 seconds later when the sweep is done. Btw, if you hit the gas while the gauge is sweeping, it will revert back to reading like normal. |
04-03-2013, 01:12 PM | #13 |
Drives: 2013 Camaro 2LT RS, Convertible. Join Date: Feb 2012
2013 Camaro 2LT Convertible
Yep, only the 4 pack in the center console sweep, not the dash gauges.
01-16-2015, 04:10 PM | #14 |
Drives: 2015 Camaro 2SS Join Date: Jan 2015
I have the same situation with my 2015 SS, I wonder if anyone found a solution!
Thanks |
