![]() Drives: 2012 Victory Red 1LT/RS Join Date: Oct 2012
Disconnecting neg. battery terminal
So I've made a few mods to my 2012 V6 with a few more to go. I want to pull the negative battery terminal to have the car relearn everything. Besides reprogramming the radio stations (and prolly reset the clock) what else can I expect?
I forgot to add it's a 1LT/RS w/ the connectivity package. TIA
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 5.7L Tundra Double-Cab X-SP Join Date: Mar 2012
I disconnected mine and all I had to do was recalibrate the windows. It takes like 30 seconds. All my presets were fine.
![]() ![]() ![]() ![]() ![]() Drives: '12 2LT Convertible Join Date: Mar 2012
Radio presets are safe.
You'll need to re-index the windows and update the clock.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
Thanks. I'll read up.
Her Name is Mila
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS Join Date: May 2012
Is it necessary to do this for a axle-back exhaust?
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#7 |
Her Name is Mila
I didn't think it was just making sure!
Thank you Colin Gordon
#8 |
![]() Drives: 2012 r/s Join Date: Sep 2012
#9 |
Her Name is Mila
What would be the difference if I welded it or clamped it? I mean wouldn't you either have to disconnect it or not for a axle back not wether it's welded or clamped right?
#10 |
Drives: nothing Join Date: Nov 2010
I did that when I installed my CAI and now my Camaro thinks it's 10/19/09 (it's birthdate)
#11 |
Her Name is Mila
Change it through the menu? Or I that doesn't work disconnect the battery again?
#12 |
Drives: 45th anniversary edition v6 3.6L Join Date: Sep 2012
So I was told no reason to that the lfx engine relearns with out. Fuse pull or battery disconnect. Should I do this with my cai inc. I have noticed over past few weeks I seem to be climbing to better gas milage.
#13 |
Her Name is Mila
Now that you say that I believe your right the LFX engine does relearn on its own I don't believe it requires a battery disconnect or fuse pull
#14 |
![]() Drives: 2012 45th Vert 2LT/RS Join Date: Apr 2012
I was told it may take some time for it to learn, whereas it will be quicker if you disconnect.
