11-07-2012, 08:47 PM | #1 |
WICKDSS
Drives: 2011 1SS/RS IOM LS3 Join Date: May 2010
ZL1 Pump on NA & Nitrous?
I am looking to beef up my fuel system for safety with the occasional 100 - 150 shot of nitrous at the strip. I understand that it may not be necessary now, but would rather address this issue this winter. I am running a TSP 231 cam, ls3.
If I replace the fuel pump with the ZL1 pump will the car need retuned? Or would I be better off running something like a lingenfelter boost a pump on a switch with the nitrous?
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei 11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds. |
11-07-2012, 09:11 PM | #2 |
ZL1 pump is a very nice pump. I am just at 600rwhp and I hold 58psi under WOT. I think some people on here are way over me running a ZL1 pump.
You do not need a tune just change pump plug and play. |
11-07-2012, 09:36 PM | #3 |
WICKDSS
Thanks! Was just curious, wasn't sure if the pressure difference affected the injectors.
11-08-2012, 06:22 AM | #4 |
Drives: 2010 CGM 2ss/rs M6 Join Date: Feb 2012
For.what the cost of the pump is and the labor you will pay, why not get a standalone fuel system? You can find them around 500 used , 700 brand new, then you can run race gas in it and run more timing for more power without having any dips in fuel pressure like spraying from the fuel rail does. Nitrous outlet and nitrous express make great ones.
11-08-2012, 06:27 AM | #5 | |
WICKDSS
11-08-2012, 08:44 AM | #6 |
much eaiser install too!!!
11-08-2012, 08:56 AM | #7 |
Banned
Drives: 2010 SS Join Date: Oct 2012
11-08-2012, 09:10 AM | #8 |
WICKDSS
Ok, what's the reason?
11-08-2012, 09:12 AM | #9 |
Drives: 2010 camaro ss Join Date: Nov 2012
I ran a 225 shot on a 231/236, making 700rwhp and had enough fuel, was just starting to run out at 7k rpm, so you should have enough. That being said, the ZL1 pump is a good cheap upgrade
11-08-2012, 09:35 AM | #10 |
Banned
11-08-2012, 09:39 AM | #11 |
WICKDSS
Good point. I suppose in a rollover wreck that could happen. I hope to keep the shiny side up!
11-08-2012, 09:44 AM | #12 |
WICKDSS
Holy cow! That's a lot of horsepower on the stock system. Its been said on here a few places that ls3's fuel system is good only to around 550 rwhp! What setup are you running now?
11-08-2012, 10:06 AM | #13 | |
Banned
There is a reason cars don't have it anymore. That's all I mean. If your going to just race the car it won't really matter I guess. But if it's a car you street and put other people in, I'd tell you having an access panel would just be irresponsible. |
11-08-2012, 10:07 AM | #14 |
Banned
