Old 11-10-2012, 08:32 PM   #1
MyOrangeSS
MyOrangeSS's Avatar
Drives: 2010 Camaro 2SS
rocker arm ?
I saw a facebook post where a friend put on the scorpion 1.8 rocker arms up graded from the stock 1.7 RA. What is this doing for him and with a more aggressive cam is it smart for me to do this or just stay with the 1.7 RAs?
- 708 RWHP 619 lbs of torque: Livernois Stage 2R MAX cam, OBX LT w/o cats, Vortech V3 w/ 3.33" pulley making 8.2 lbs of boost, MBRP exhaust, ZL1 fuel pump, KB BAP, FAST 85lb injectors, tuned at American Intense Racing
MyOrangeSS is offline   Reply With Quote
Old 11-10-2012, 10:13 PM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
No, you should not go to 1.8s with an upgraded cam. You may run into piston/valve clearance issue. If the cam was built with 1.7s in the equation, you should stay with 1.7s. Putting 1.8s on a stock cam, give the impression of more lift.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
rocker arms, valve train
