![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LLT/RS Join Date: Apr 2012
Roll window up and down light?
Ok, So this just started last night but I was driving in my car and then in the center display (like where the speed limit and car information is shown) it says to roll my driver side window down and then back up, and then I do it, and the warning sign doesn't go off. I haven't done any mechanical mods to my car and so it wasn't anything that I did, but I have absolutely no idea what it means. If it doesn't stop I am gonna take my car to the dealer to see if they know what it is, but I was wondering if any of y'all had any idea?
#2 | |
2G1FK1EJ9A9129110
window relearn
0000: 06/17/09-(gary lang Chevrolet) 1100: 06/17/09-(preliminary order accepted) NKPQ3N 2000: 06/22/09-(accepted by gm) 3000: 06/24/09-(accepted by production control) 3300: 07/14/09-(order scheduled for production) 3400: 07/18/09-(order broadcast) 3800 07/24/09-(2G1FK1EJ9A9129110) ![]() 4000: 07/24/09-(available to ship) 4200: 07/28/09-(shipped) 5000: 08/05/09-(delivered to dealership) 6000: 08/06/09-(delivered to customer) ![]() |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
You might want to try indexing both the driver-side and passenger-side windows. Maybe that will clear it???
![]() BTW- the "...like where the speed limit and car information is shown..." is called the Driver Information Center, or DIC. There have been a lot of sometimes funny posts related to the car's DIC...
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
Rockin' Steady
Drives: 2010 Camaro 2SS Join Date: Apr 2012
If the light did not go away after doing the relearn, the relearn was not performed properly.
I know it seemed really straight forward but when or if the light comes back on, make sure the car is in park, car not moving, hold the button down for a couple of seconds after the window is rolled all the way down and the roll the window back up and also hold the button for a couple seconds when its all the way up and that should do the trick. If this is what you did and it did not relearn, you have a problem with a module or component and you should get it diagnosed to prevent you windows from losing their relearn and being stuck half way open or closed, to prevent a costly water damage etc... These car can lose their window learn from day to day sometimes, dont ask my why they just do.
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators. |
![]() Drives: 2010 2LT...Black Join Date: Jul 2012
Happens to me but after I do it, the message goes away.
#6 |
Thanks for the help! I think I wasn't holding down the switch long enough while rolling them up and down because it went away once I held it down for 10 seconds or so! Thanks!
#7 |
![]() Drives: 2012 Crystal Red Tintcoat RS Join Date: Apr 2013
I did what DJ BigC said and it fixed my problem. Thank you.
#8 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
this happened to me during header install when I reconnected my battery and started her up it said the window thing but went away 1st try.... think yours is screwy or something.
#9 |
![]() Drives: 2011 Camaro ss Join Date: Aug 2020
windows up/down
ok.. 2011 camaro ss , my car was doing the same thing , then brake light and some other light stays lit up also telling me to service stabilltrak , it would run fine then act up and left me siting , help ?
Thanks stagg |
#10 |
Sounds like an electrical problem. Could be battery or grounds. Has any work been done on the car recently ?
#11 |
About a mo. ago had plugs and wires changed about it
#12 |
Check easy things first. Battery voltage (how old is the battery?) and battery connections, especially negative cable connection to trunk floor. As you have an early year 5th gen there were known problems with the trunk ground that was fixed with a Service Bulletin
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
Those are classic signs of a battery going out in these cars, it may even test ok with a voltmeter, but it probably fail a load test.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
#14 |
Yup battery was bad and wire from the fuse box had to be repaired , thank you for input
