![]() Drives: 2010 camaro Join Date: May 2010
v6 bumper on a v8
What all do I need to install a v6 bumper on my v8? Besides the bumper and the lower grill.
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
that rubber deflector underneath the fascia is different, but the SS version is longer by a couple inches, so you could just cut yours with a pair of scissors. Why go with the V6 fascia? Going for a sleeper look? The lower grille on the V6 is significantly smaller, may cause your car to run a little hotter than usual.
Soloknight6- yes I'm trying to go for a more sleeker look. And I also plan on putting an aftermarket cold air intake on the car as well. Do you think it would help?
Oh, and do you have any idea on how I can get the part number for the lower rubber piece for the v6?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 5.7L Tundra Double-Cab X-SP Join Date: Mar 2012
Is your car yellow?
If it was Ashen Gray I'd gladly trade you lol. |
#6 | ||
![]() ![]() ![]() ![]() ![]() Drives: Black 2011 Camaro LS Join Date: Feb 2011
You will probably need the wheel liners. The V6 liners are more curved/less square than the SS. The SS fascia will Fit over V6 wheel liners, but the V6 fascia might not fit over the SS wheel liners. If it doesn't you could also cut them.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob SS Fascia, Factory RS HIDs, Plasma P13W fog lights Non-RS to RS and fog light harness by Gen5DIY LED Interior, Trunk, and Licence Plate lights in white ZL1 Spoiler with Gen5DIY harness Factory NPP cat back Blacked out tail light bezels Factory 20 inch wheels wrapped in Nitto Motivos Lowered 1.25inch on Eibach Pro springs |
