Old 11-17-2012, 08:55 PM   #1
SixCyl
SixCyl's Avatar
Drives: 2010 Camaro CGM V6
Rear speaker upgrade
Alright so the title explains what I'm deciding on whether or not to do. Here's what I know so far:
1. I will hate my car (and Chevy and GM) and say terrible things to it that I won't really mean for about 4 hours because of the back seat. I can live with that.
2. ********.com, get an adapter
3. Amps are optional, will probably skip that.
Here's what I don't know....
The stock (non-BA) speakers are what "way"? I keep seeing 2,3, and 4 way speakers.
What wattage speakers should I buy if I'm not buying an amp?
Is there any sort of compatibility issue I may not be aware of, including the above questions? Far as I can tell, I can just splice and replace?
For example, would these be more or less plug and play?
Pioneer
Rockford
Dual
EDIT: If you had to choose, would you replace the rear speakers or the door speakers and possibly the tweeters?)
El gato. Mods: Eagle eye headlights, 18" Axis Sport graphite, Roto-Fab cold air intake, Vmax ported TB, 3/8" Vmax Black-Ice, RX single valve catch can, RX breather, Pedders inserts, Trifecta tune, BBK LTH 304 SS.
art/ärt/Noun. Definition: 5th generation Camaro.
SixCyl is offline   Reply With Quote
Old 11-17-2012, 09:30 PM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
In general, without an external amp, I'd probably be looking to the spec for efficiency. db, sometimes expressed as dB at 1 watt, is the measurement, and the higher, the better. You don't really "blow" speakers because you overpower them, it happens more often when you try to drive them past the amplifier's capability and send them a "dirty" signal. You'll get a better overall sound, probably louder, with a most efficient speaker, so compare them. Over 90 db is getting there, but I'm sure there are better. Balance that with a known quality manufacturer and you'll come out far better than stock.
Good luck with the rear deck.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 11-18-2012, 12:12 AM   #3
Decibel JJ
Car nut
Decibel JJ's Avatar
Drives: Tahoe Z71, Race cars
Anything more than a two way coaxial speaker is ridiculous. Most good coaxial speakers will have a decent tweeter and that'll do the job (especially for rear fill)
I personally would do the front speakers first because I like a good front soundstage.
Quote: Don't you just hate it when Satan steals your ride and does all these weird ass mods to it?
R.I.P. Evan .. A true Friend
Decibel JJ is offline   Reply With Quote
Old 11-18-2012, 12:29 AM   #4
SixCyl
SixCyl's Avatar
Ok cool, is this one those "pretty much anything is better than stock sound," sort of thing?
Old 11-18-2012, 11:33 AM   #5
SixCyl
SixCyl's Avatar
Would I better off just upgrading the stock amp instead of any speakers?
EDIT: there is no amp in my car apparently...well at least I'm learning something, lol. Alright so I guess the question is now, should I get an amp? I was unaware my car didn't have one and I was cool with having a "stock" amp. All I would have to do is connect at the wires going to the rear speakers and then hook the other side up to the rear speakers right? Stereo======Amp=====Speakers?
Old 11-18-2012, 04:56 PM   #6
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
I am not an expert, but I did upgrade my non BA system front speakers with Phoenix Gold Ti 65 component speakers. It sounded much better but needed rear fill. Added rear Ti 69's and it sounds great. I may not do any more upgrades because I really like the way its sounds, but I think an amp and sub would make the system completely awesome. Hope this helps.
Cuda7050 is offline   Reply With Quote
Old 11-18-2012, 05:03 PM   #7
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yes, you'd probably be better off installing a quality amp. Really depends on what you're looking for. Why are you wanting to replace the speakers? Because you don't like the volume, sound quality, or what? Also, what's your budget? That really helps in giving advice.
Old 11-18-2012, 06:48 PM   #8
SixCyl
SixCyl's Avatar
Well, I'm not looking into doing it right now. Just trying to see how feasible it is. My budget is probably $120. I like my sound quality ok, but there is a popping/crackling noise from the front speakers sometimes. It doesn't distort the sound it just literally adds small pop sounds in the middle of songs. Also, I heard a car with a Bose system and that sounded great. Obviously I'm not about to drop the hundreds and hundreds for Bose but I figure it's not hard to do better than stock. Though the stock speakers are pretty good.
Old 11-19-2012, 10:41 PM   #9
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
replace the front speakers. I just installed Memphis M class 6x9 in the back, They drove me crazy, swaped to polk MM 691 they sound like giant tweeters. trying to get the back to sound right with out a proper front stage is a bad idea. I will say save up another 120 and get some good and I mean good front components. 250. bucks. I am sure there are some others for less. I was looking at polk MM 6501, JL c3's and like to have drove myself crazy finding a place to hear them. the polk are like 189.00 220 for the JLs I beleve there are some focal for around or less than these. not sure about them. I finally just bought some hertz hsk 165's after hearing them.
mgoodbar is offline   Reply With Quote
Old 11-26-2012, 02:00 PM   #10
SixCyl
SixCyl's Avatar
I dropped the idea of the speakers and decided I didn't need them but I stumbled on some money (literally) and am looking into the front speakers again. From what I gather, I should buy just component speakers for the doors, not coax or above?
Old 11-26-2012, 04:05 PM   #11
DangerZL1
Drives: 2023 Black ZL1 Auto
Does the non-BA system have tweeter pods on top of the door panels? I have the BA system and I would only replace the fronts with separate components just like the original system has.
DangerZL1 is offline   Reply With Quote
Old 11-26-2012, 06:32 PM   #12
lscamaro
lscamaro's Avatar
Yes, the non-BA system has the seperate tweeter pods like the BA system. The non-BA system has even been proven to have the exact same front speakers as the BA system.
Yes, I would go with some components. Most 6.5 and even a lot of 6.75 will work with the Camaro. Depending on what you want to spend, will dictate what you put into it
Old 11-26-2012, 07:07 PM   #13
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
I had that popping cracking sound all so. I install some Infinity Kappa 6.5 components speakers and dynamatted the doors there no more popping and cracking now.
Caddy
Caddyroger is offline   Reply With Quote
Old 11-26-2012, 07:22 PM   #14
lscamaro
lscamaro's Avatar
Did you get the infinity kappa tweeters to fit in the stock location? I saw them and they are HUGE!
rear speaker, upgrade speaker
