Chris
Drives: 2011 2SS RS Jewel Red 6.2L Vert Join Date: Jul 2011
L99 Transmission Sticks In First
Hi Everyone,
I have had my 2011 6.2L L99 transmission stick in first gear about five times since I bought the car about 18 months ago. 4 of the 5 times it occurred after starting it and driving from the house in the morning. (I live in AZ so it doesn't get cold here.) It will stay stuck in first until I pull over, shift to neutral, then shift back into drive. Then all is ok. Last week on the way to drop off the car at the dealer for an oil change and top inspection (yes, it's a vert), I was driving in 3rd or so at about 25 mph when it shifted down to first and stuck there. That was really weird (and scary). Again, I pulled off, sifted to neutral, back to first and all was ok. I reported this to the dealer. They ran all the diagnostics and found nothing. They also said they checked with Chevy if the issue has ever been seen. Again, nothing. They couldn't get it to repeat. I think the next time it happens, I will leave it alone and drive to the dealer (slowly) just so they can witness it. But in the meantime, has anyone ever seen this? Thanks Chris |
![]() Drives: 2012 Camaro 1ss Join Date: Jun 2012
NO, However I have noticed that there is a little "hiccup" or slip when it shifts into 2nd.. Almost like it sticks for a brief moment, however my research has shown this transition from 1st to 2nd commonplace. Too bad the dealership couldn't get the problem to repeat while you were there. Hopefully there are no serious problems.
![]() ![]() Drives: 2011 camaro 2ss/rs rally yellow L99 Join Date: Nov 2011
Do you have any aftermarket shifters? Cus when I bought my hurst paddle shifters I put the downshift on a little to tight and it would downshift on it's own. It took me a few days to notice and it kept on scaring the crap out of me ...and if you have the stock ones I would just sit there for about 10 minutes and just keep tapping the down shift from different angles to see if it gets stuck.
- Airaid cold air intake - Kooks 1 7/8 long tube headers
- Kooks high flow cats - Borla atak 2.5" cat back exhaust - Dyno tune - AFM delete - 94 octane tune - Vitesse paddle shifters - Blacked out rims - Costum painted engine cover - T3 stripes - GM locking gas cap Last edited by SuperSport2011; 11-19-2012 at 02:55 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
On the interstates @ 60-75 mph in "D", if I slow down or stop for any reason and then speed back up, my L99 SS will stay in 5th gear and not upshift back into 6th gear. I must then put it in "S" and then manually upshift.
I've had the car to 2 dealers but they can't duplicate the problem or show any problem on the cars computer, so they say there's nothing they can do.
![]() ![]() ![]() ![]() ![]() Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
I think that this is your answer. The dealer is not going to take it seriously until you prove to them that it's really happening. Maybe they can hook up a scan tool and figure out exactly what's happening, if they catch it in the act. I think I'd pull up in front of the dealer, leave it running, in gear and set the parking brake. I'd be afraid that shutting it off or shifting gears would take it out it's failing mode.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service
#7 | |
I guess GM is only interested in L99 transmissions that get stuck in 1st gear, not 5th.
#8 |
Chris
Good question on the mileage. The vehicle is at 18,995. Other than the top, I've have very few things go wrong. And about the transition, I feel it shifts very smoothly. I'm thinking that some sensor is dirty - or somehow it's getting a signal that the car is in manual when it is not.
#9 | |
#10 | |
#11 |
Chris
Thank you. I really do love it. It is very comfortable, smooth and just looks good. I still get people yelling out the windows as I drive by. I've never had that happen in any car I have had. I know this is off topic but the only thing I would think about doing to it is supercharging. I'd like to have a bit more power (if you can believe it.)
The next time it happens, i will check all the things you mentioned. However, my heads up says 'S' when I leave it in that mode. And you know what? It shifts anyway! And when in drive, the paddles still work. I really don't know the difference. The button is to disengage for movement. It doesn't feel abnormal but I'll check that too. Thanks for the reply. Here's another pic. Red Jewel - we may never see it again. |
#12 | |
I've had the car to two Chevrolet dealers who advised there's nothing they can do unless they can duplicate the condition as nothing shows on the shops computer. Neither one could. A case number was set up plus the above info supplied already. It's upsetting to me that GM cannot correct this problem on my Camaro. Happy Thanksgiving. Keith, 860 539-4686.
#13 | |
#14 | |
I went to Boston and back over the weekend and again my Camaro sticks in fifth gear after slowing down on the interstates. I am not lying about this and I find it hard to believe GM will not try to correct the problem for me. There can be only one or two causes for this imo so can't something be tried ? Again, this only occures when after driving an hour or two on the highway, so I don't see how I can take a dealer's tech on such a trip to try to duplicate the problem. Please review my two prior posts on this (above) and try to help me. Thanks, Keith.
