Autoboticus Roboticus
What else should be upgraded when installing lowering springs?
I just got me some Pedders springs. I figure if I'm taking stuff apart anyway, I might as well do some upgrades while I got everything tore down.
I'm already planning on installing sway bars at the same time (with poly sway bar bushings).. I'm also guessing sway bar end-link bushings too and trailing arm bushings? So, without having to read and remember the entire Gen5 Camaro upgrade "BOOK", what else would be easy access to do? (though, that post/book has a lot of good info in it as I found when skimming it). Not going for a track setup.. My cars primary function is a daily driver, cruisin on the twistys car.. Maybe I might do some track days next summer. Advice is appreciated.
HT5 EastSide
I heard sub frame bushings and the control arms should be upgraded along with the sway bars. where is that book anyway?
Drives: 2014 Z28 camaro Join Date: Sep 2009
Sub frame bushings or inserts,sway bar with bushings,end links and your springs should make nice improvement.
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
The book
http://www.camaro5.com/forums/showthread.php?t=90270 How about ZL1 lca's and rear sway bar? Pedders radius bush, cradle inserts are a must and they are the foundation to the suspension. You should know that since you have seen the book. Inserts, radius bush, you have good springs now and the rest is up to you. I loves me some Pedders
My Build Thread
http://camaro5.com/forums/showthread...=1#post5036900 Maureen@Rodgers Chevrolet...The best prices and customer service period!!(734)676-9600 Gen5Diy.com.....http://www.gen5diy.com/ Wretched Motorsports..www.wretchedms.com/ Pedders USA...http://www.peddersusa.com/ |
#6 |
Drives: His Wife Crazy Join Date: Jan 2008
As Bruce and a couple of others mentioned, the Radius Rod Bushings would be a good place to start, as well as the subframe bushings.
There are a few choices for each of the parts depending on how aggressive you want/need. You don't have end link bushings to replace, the end links that are on your car are double ball links, however the ZL1 swaybar is the hot ticket for the SS cars, and we have a conversion kit that will include the sway bars, bushings, links, and rear lower arms due to the updated location of the swaybar links on the ZL1 bar. These recommendations are something that i would recommend regardless of installing lowering springs, they are just good recommendations period. |
