Old 11-21-2012, 08:22 PM   #1
ubrimah
Oreo
ubrimah's Avatar
Drives: Summit White LT/RS A6
Looking to invest in subs
So far 'm looking at two options.
1) http://www.wishlist.com/ubrimah/christmas/ plus maybe an enclosure for the amp or
2) http://********.com/Chevrolet-GMC-Su...w-clone-1.html
Price wise the Jl set up is about $468 or $548 with the amp enclosure and the ******** setup is $575. I've read in several places that the jl 10w3v3 is one of the best subs out there and overall the setup is a bit cheaper but I would love some insight from you guys.
Click the pic!
ubrimah is offline   Reply With Quote
Old 11-22-2012, 09:55 PM   #2
Go big or Go home
Go big or Go home's Avatar
Drives: 2010 Camaro 2LT RS
The links you provided don't give much information on the particular subs/amps your looking at so I can't help you much with specifics. However you are comparing two pretty different things. The JL is a 10" where as the the Kicker is a 12". The 10" is going to hit a higher range of bass than the 12". Also, JL is known for crisp, clean sound; it is a very good brand if that's what your looking for but you will get more bass from a Kicker. So the better option really depends on the amount and range of bass your looking for.
Go big or Go home is offline   Reply With Quote
Old 11-23-2012, 12:53 PM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
It depends on what you want really. If u want loud boomy bass, then the 12 will outperform the ten in that regard. If you're looking for clean crisp bass, the w3 is a decent option in that regard. But it will be better than the kicker if you're looking for clean
subs
