11-24-2012, 06:30 PM | #1 |
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Help! TVS2300 install question.
So I plugged the 2 prong connector onto the intercooler pump. There is only one way for this clip to go on. However the black wire is connected to the terminal marked positive and the red is connected to the negative terminal.
Is this normal? Do these pumps spin backwards? Trace them back to the relay and the black spade has 2 wires on it, one going directly to ground on the fender. So you can't just flip them there. I'm ready to flash the ECM and fire it up, once I get this sorted out. Thanks in advance.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
11-24-2012, 07:03 PM | #2 |
Drives: Anything Blown Join Date: Aug 2010
According to Brian, its fine. plug it in and fire it up!
11-24-2012, 07:09 PM | #3 |
Alright thanks!
11-25-2012, 10:09 PM | #4 |
Update,
I have been filling the reservoir and carefully watching the coolant flow and it is definitely running in the right direction. From the reservoir to the pump.
11-26-2012, 06:00 PM | #5 |
Drives: 2006 Crownline Join Date: May 2012
Yep, that is right.
