Old 11-24-2012, 10:50 PM   #1
Tusk
Emerald Coast Camaros
Drives: E350
Daytime Halo's and red trim rings
Installed new LED's on the halos and added trim rings. The new LED's are 5 watt, replacing the 1 watt stock SMD's, and the rings are circuit-on-board style. Another vendor calls the C.O.B's plasma lights. The halos are now on a separate circuit so they can be on without the parking lights, although I have to remember to turn them off, or the headlights on without the halos. I followed gator6977's DIY for the install (THANKS gator6977). The trim rings are also on a separate circuit.
Sorry for the crappy pics, i need a new camera.
Tusk is offline   Reply With Quote
Old 11-24-2012, 11:35 PM   #2
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
That looks awesome! Wayyy better than seeing individual LEDs!
Where are the COBS from?
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 11-25-2012, 12:16 AM   #3
Tusk
Drives: E350
I bought them from www.superbrightleds.com. They have everything for DIY. The COB's are available in multiple sizes, including HID and DRL trims. I used the 80 mm size. The COB's come complete with drivers, the 5 watt LED's needed separate drivers. The correct puck drivers are shown on the pics.
Old 11-25-2012, 02:34 AM   #4
Synerbee
SoCal Headturners
Synerbee's Avatar
Drives: 2010 SGM
those 5w halos look good and so do the red demon eyes! If you can get a picture next to a new model BMW I would love a side by side comparison to get a reference to how bright the 5W LEDs are in person
Synerbee is offline   Reply With Quote
Old 11-25-2012, 12:43 PM   #5
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
Careful. Remember that the stock halo-LED heat sinks were designed for 1W parts.
sjmautoprod is offline   Reply With Quote
Old 11-25-2012, 08:07 PM   #6
Gator6977
Gator6977's Avatar
Drives: 2011 2LT RS
I've left my 3w' s on for almost a full day with no adverse affects. Still going strong too! Tusk, those look frickin' awesome! It might be getting close to time to reopen mine! Well done sir!
Gator6977 is offline   Reply With Quote
Old 11-25-2012, 08:42 PM   #7
Jaime068
Treasure Coast Camaro 5
Jaime068's Avatar
Drives: 2010 Camaro 1LT/RS RJT
This is what I want to do for Xmas! How was the install?
Jaime068 is offline   Reply With Quote
Old 11-25-2012, 08:55 PM   #8
Blues45th
Drives: 45th anniversary edition v6 3.6L
I bet crack and bake. No thanks not on my stock halos. Yikes.
Blues45th is offline   Reply With Quote
Old 11-25-2012, 09:55 PM   #9
Tusk
Drives: E350
Thanks. I am already planning on opening them up again. Thought about another modification while wrapping this one up. Will have to order more parts first.
The install was straight forward. I waited overnight for the adhesives to cure before proceeding to re-assemble the front end, so start to finish was a full day. Removing the front end took a little over an hour, and 30 minutes to put back on. Baking the lights is required. I put all the wiring in cable trays, and pulled some spares for future use.
Old 11-26-2012, 12:46 AM   #10
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Looking really good! Nice work.
CamaroFTW is offline   Reply With Quote
Old 11-26-2012, 12:49 AM   #11
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
that looks great man
Old 11-26-2012, 04:30 AM   #12
Wooden Heart
Wooden Heart's Avatar
Drives: 2012 Camaro LT
I just bought my retrofit kit and rgb halos. I can't wait for the install day.
Wooden Heart is offline   Reply With Quote
Old 11-27-2012, 12:55 PM   #13
Jaime068
Jaime068's Avatar
What would I need to buy to install the halo fog lights? The halo's themselves? Any wiring or harness'?
Old 11-28-2012, 02:48 AM   #14
Gator6977
Gator6977's Avatar
Drives: 2011 2LT RS
Jaime, you can buy the RGB (multi-color) ones and all the wiring, which isn't that much, comes with them. The same is true if you go with a single color. Either or, it's all pretty straight forward and not all that difficult. The only snafu is opening the lens's. Your best bet is a band saw as many have had bad instances with fast moving cutters, i.e. 3000 rpm dremel. The plastic melts really quickly. This link has about all you need and at about the best price you can find. This is one of the next mods on my ever growing list.
http://www.superbrightleds.com/cat/l...accent-lights/
