Old 11-26-2012, 05:21 PM   #1
murdered
Drives: 2012 2SS 45th Ann. Edition
Question Would this be everything?
I'm compiling a list of parts for adding in a sub. I also want to get a nicer Amp and someone said the HD900/5 fits in the BA spot with the amp mount. Currently I have:
  • HD900/5
  • FARK and Amp mount from ********.com
  • Passenger side 10" enclosure
  • JL 10W3v3
Is that all I would need to get up and running? Should I worry about the amp overheating in the stock location w/ a mount, or is there decent air flow through there?
2012 2SS 45th Anniversary Edition
murdered is offline   Reply With Quote
Old 11-26-2012, 06:30 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
The amp should be fine. A bunch of members have replaced the stock amp with an amp from jl in the stock location and been fine. I don't see why yours would be any different.
And to answer your question, it looks like you have everything you need except for power and ground wire that you need to power the amp
Old 11-26-2012, 06:44 PM   #3
murdered
Awesome, thanks! Now I just need to hope the 10W3 is loud enough
Old 11-26-2012, 06:45 PM   #4
lscamaro
lscamaro's Avatar
Have you ever heard one in person?
Old 11-26-2012, 06:47 PM   #5
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Here is an older post of mine that compares the dimensions of the stock location and the HD900.5.
Also, you're going to need an amp install kit, think power, speaker wires to go to your sub, and some fuses.
Originally Posted by jeepguy_1980 View Post
Originally Posted by flyer08 View Post
Thanks, the stuff is in the mail so I havnt had a chance to check to see what fits where
While I'm sure you could force it to fit on in the factory location, I don't think it's ideal. If you want all the materials ready for your install just check out the specs below. The HD900/5 is .24"x.54" too big. This is how mine looks.
Originally Posted by ********.com
2010 & Up Camaro Factory Fit Amp Mount
Effective mounting area: 7.75" x 10.5"
Amps larger than this will not fit
Originally Posted by JLAudio.com
HD900/5: 5 Ch. Class D System Amplifier, 900 W
Height (H) 1.93 in / 49 mm
Width (W) 10.74 in / 273 mm
Depth (D) 8.29 in / 211 mm
Net Weight 6.85 lb / 3.11 kg
jeepguy_1980 is offline   Reply With Quote
Old 11-26-2012, 06:54 PM   #6
murdered
Nope. I haven't found a good audio shop in the area, and I'm not a fan of BestBuy.
Guess I should have stated that I'd get fuses, etc. I've done an audio install before, but that was 8 years ago.
Would you recommend mounting the amp somewhere else? I originally had picked the HD900/5 because I thought it could be mounted in the stock location. If I'm mounting it somewhere else I'm willing to get a bigger/better amp.
Old 11-26-2012, 07:00 PM   #7
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
The only problem you is have is the rca cables for the input. It would be doubtful it will fit the stock opening. I have the JL XD400/4 installed. It is 73/8 wide. I had to mount the amp all the way to the top of the board so I could get the amp and RCA cables to fit. The RCA cables are at a sharp 90 degree angle after fitting it in.
Caddy
Caddyroger is offline   Reply With Quote
Old 11-26-2012, 07:25 PM   #8
lscamaro
lscamaro's Avatar
If you want to mount in the stock location, the jl audio xd 700/5 will fit if you want a 5 channel.
What are you looking for as far as bass output goes?
fark, jlaudio, subthump
